Go Back   TDIClub Forums > Forum and Web Page Info > TDIClub and TDIClub Forum News, Issues, Problems and Suggestions
TDIClub and TDIClub Forum News, Issues, Problems and Suggestions This is the place for updates on the website and forums. This is also the spot for forum questions, comments, ideas, gripes, requests, etc. This forum is NOT for posting problems about your car. Non-topic posts will be moved or removed.
Old February 6th, 2019, 07:03   #1
ejoskf
ejoskf's Avatar
Default Over-fueling engine 1.9 TDI PD 130
Hey
I am new to TDI world, I've got 2004 Passat my engine seems to be running rich. It's winter but fuel economy is poor, can smell unburned fuel after engine warmed up, on acceleration there is a smoke behind me. Also on start up there is puff of blue-ish smoke but doesn't look like and oil. I've cleaned EGR, inlet manifold and done full service as well as new fuel filter and thermostat with coolant change. Fuel efficient is 40mpg mixed driving best 50 motorway (imperial units) any ideas?
Thank you
Sent from my CLT-L09 using Tapatalk
ejoskf is online now   Reply With Quote
Old February 6th, 2019, 07:52   #2
BlueMk4Golf
TDI(s): 1.9TDI
May be the pump is serving more fuel than it should. Im not to sure about what could be your problem. Hit up your local mechanic and see if he has any solutions
Sent fra min SM-G960F via Tapatalk
BlueMk4Golf is offline   Reply With Quote
Old February 8th, 2019, 09:10   #3
ejoskf
ejoskf's Avatar
Thank you. I've attached some images in this post
https://r.tapatalk.com/shareLink?url...1&share_type=t
Old February 12th, 2019, 13:12   #4
CasaEd
TDI(s): VW Passat B4
When you changed the oil was it the correct amount that came out and also did you smell the oil to see if it had a diesel smell ? The injector readings look fine.
The only thing that springs to my mind is that the injector seals may be leaking,
probably not all of them because that usually raises the oil level pretty quickly.
Blue smoke is oil burning, maybe worn valve stem oil seals, or worn turbo.
how many miles does the engine have on it ?
CasaEd is offline   Reply With Quote
Old February 13th, 2019, 07:33   #5
ejoskf
ejoskf's Avatar
Thanks. I've just hit 85k I know very low for 15y old car. Turbo I think seals are failing. I've had it apart when doing tensioner and than again 2 weeks later and about 1-2 table spoons of oil came out. Could that cause that puff of smoke on startup?
tdi pd 130 awx engine bellows smoke when started cold. sam2dads TDI 101 1 November 24th, 2014 00:33
Atd 100bhp pd golf engine on asz 130 pd bora tod123 VW MKIV-A4 TDIs (VE and PD) 4 December 26th, 2013 10:06
passat pd 130 tdi engine code audi80tdi TDI 101 0 January 26th, 2010 14:02
130 hp PD engine FS westyman Private TDI Items for Sale/Wanted 13 April 5th, 2008 16:55
02 bora pd tdi 130 engine problem plz help gaz130 VW MKIV-A4 TDIs (VE and PD) 2 September 23rd, 2007 18:47
Page generated in 0.12517 seconds with 12 queries
[Output: 68.24 Kb. compressed to 60.49 Kb. by saving 7.75 Kb. (11.36%)]
