Funguy
- Joined
- Jan 18, 2005
- Location
- Front Range of Colorado
- TDI
- 2015 Golf Sportwagen dsg and 2015 Passat 6 M/T
FYI to help if you have a rattling noise
I had a rattle at idle. I finally got around to looking for it and found it to be the top engine cover forward of the oil filter cap. I cold see the mark on the underside of the engine cover.
I used top technology to fix this: I glued a garden hose washer over the spot with gunk glue. Problem solved.
