Earlier this year, when the weather was cooler, my B4 would have a rhythmic squeak when starting cold. Any kind of additional load on the belt (AC on, or lights on) would exacerbate it, but in any case it would go away after a minute tops. There was quite a bit of rapid wobble in the serp belt tensioner, regardless of temperature.
Fast forward to the jungle-like temperatures in the PNW lately, and now it no longer squeals at first start, but when starting after being already warmed-up, even a couple of hours later. The noise is similar (rhythmic and middle-pitched, not the steady high-pitched shriek of a typical belt), but louder. Load does not appear to affect it, and it lasts a bit longer than the cold squeal did before.
In both cases, when under way and driving there is no abnormal noise whatsoever. Engine sounds and feels healthy. Car has just under 160k, and the alternator is probably not original. I did timing belt about 2k and six months ago, with a new Litens tensioner and new INA roller.
I'm going to remove both the PS and serp belt tomorrow to be sure it's not the timing belt, but assuming that checks out and it is in fact the drive belts... what should I focus investigative efforts on, given the symptoms? The harmonic balancer? The idler tensioner? The whole idler assembly? The alternator pulley?
