runninlean
Hello, I'd like to apologize in advance for my first post being a problem with my car post. I've always been able to find problems with Bing and searching the archives of this site.
Yesterday the family wanted to go out for lunch and bowling. We jump in the car, I noticed my clock had gone forward in time by 1 hours and 20ish minutes. I didn't think much of it and set the clock as we headed down the road. Drove about 30 minutes, stopped the car cracked the windows and shut it off. Came back out after about 3 hours. Started the car, no odometer, trip meter, clock or speedo. Tach and all idiot lights came on and funtion on the cluster, Radio went into "safe" mode and displayed 1000. I turned on the headlamps and none of the backlighting was working either. I tried my wives key thinking my key transponder had gone bad. Same issue. Decided to drive it home, about 2 mile's down the road the speedo came back. Another 5-8 miles the trip, Odometer and clock came back, but the clock was counting the hours up like I was trying to set the clock.
Got home, shut it down. Looked for anything obvious, no coolant in the engine harness or cluster harness. Disconnected the battery for a few minutes. Hooked it back up, radio came back to life but hour meter was still counting up. Also the Radio went back to all of the pervious owners pre-sets? Checked at power and grounds that I know of with no change in the problem. Removed the cluster, found the hour set micro switch was shorted. I removed it from the printed circuit board. Hooked everything back up everything works as it should now, besides I obviously cannot set the hours.
Now I know I found/kinda fixed the hour meter thing. I just don't know why it had all the other issues, that a simple power cycle fixed. I was also thinking it was possibly a poor connection at the cluster harnesses that I accidently fixed by removing and hooking the two bail connectors back up? From looking at the schematics it appears the cluster is in charge of putting car in valet mode and theft.
Please note, it's very hot where I live and it seemed stuff started to come back to life as the a/c cooled the cabin. Sorry for the novel, just trying to give the most accurate description of what all was going on.
