Inline4
- Joined
- Mar 15, 2008
- Location
- Ohio
- TDI
- 2001 New Beetle TDI 5-speed manual (184K), 1982 Mercedes Benz 240D 4-speed manual (212K)
Just recently replaced the vacuum tubing from the N75 solenoid to the turbo
actuator thanks to the helpful (Diagnosing and Fixing Limp mode for A4 1.9TDI)
thread. The tubing I used was purchased at a local auto parts store(Armor
Mark/7/64 in. vacuum hose), a rubber hose. One week later I was experiencing
the same Limp Mode symptoms. Today I found the new tubing sheared in half
again about 18 inches from the actuator. This does look more like a windshield
washer tubing. Is the problem that I am not using the correct tubing?
Searching for a better tubing I have found this site:
http://www.hps-siliconehoses.com/hp...-tubing.html?gclid=CL2bp-OE9LkCFY1DMgodhVgAmg
Just wondering if anyone has had any similar experience with this issue. I did
temporarily fix the "Limp Mode" issue by using a inline connector. With the
tubing hooked up, I can hear the turbo "whine". When disconnected, there is
no turbo "whine" and the engine power is greatly diminished. Thank you...Carl
