Swap only nozzlesDid you install nozzles? Or you mean swap injectors.
What turbo is in stock?
**** off polo 500chikensI bet stock ibiza cupra is still quicker.
What is this **** going on here? Threads full of trollers. First comes Spanish chicken guy and now this.
pm......are they from 335?
I have power up to 4200rpm, I guess the dyno willWhy does the power tail off so fast above 3500? Heat soak?
the most difficult is to adapt the engine module, if you have a car full swap no problemnice project man. what was envoled in the conversion i.e gearbox, prp shaft, rear diff. was it a diffucult conversion to do
Hello, sry for bringig an old topic back from dead, but where did you get those nozzles and how much did they cost you?Mods
204 but 272 & 204 same engines, 272 have bigger rods onlyYou have the 204 engine or 272 engine in the car now?
