willm
Hi folks,
Just needing a little help diagnosing the smoke. The last two items I added to my car was the VNT-17 and of course the program to go with it. The car smokes even on light takeoff with ac on. The Kerma guys said that I shouldn't be getting much smoke with my setup and that something else must be wrong. I have had the turbo in awhile but have been running my old vnt-15 tune to reduce the amount of smoke. Had time to take it to the local foreign performance shop to have them take a look. They said the intake was clean (had it cleaned 2 1/2 years ago and put blocker plates in). They checked the injection values and found the air mass sensor values are to high causing a rich mixture. Do you think that just changing the MAF sensor will take care of it? Is there a particular one I should put on? Do I need a new tune? Any help would be appreciated.
Will
Will
