Hi guys,
First post
I have some quite specific questions regarding clutch wear and clutch technique.
It started off me wanting to know how fast I should press/unpress my clutch when changing gears. After reading a mass of articles on clutches i'm confused! I'm now under the impression I shouldnt use any throttle when changing gears (as revving when between open/closed clutch causes wear and referred to as riding the clutch)
I've tried changing gears this morning on the way to work without using ANY throttle and found it jerky and impossible.
The technique I normally use is *foot completely off gas - depress clutch - revs drop to 1000 - select gear - start to unpress clutch - around half way point on clutch use throttle to add revs of around 1100-2000 - unpress remaining half of the clutch - once then fully in gear add more throttle as required*
Am I causing wear by doing this?
How fast should you actually press/unpress if someone could count in seconds on a drive today would be much appriciatied - obviously 1st gear is an exception to get the car rolling - should 2nd gear upwards be a controlled 5-10 seconds press, then same on unpress, or a swift 2 second in out job?
Sorry for a complete noob post LOL
P130
First post
P130
