ARP Head Studs
Mahoutsukai
Phoenix, AZ
jackbombay said:
Ohhh, is the cam cover gasket re-useable? I have never read of anyone mentioning replacing it so I assume it is reusable, but haven't ever looked it up in my bently.
The gasket on the crank case cover does not need to be replaced.
jackbombay
Diesel knows best
A4 Jetta
jasonTDI said:
You mean the cam seal? Yes, since you aren't taking the cam out. If you pop out the cam i'd change it.
Thanks, I was refering to the aluminum thing on top of the engine that your old navy CCV filter plugs into which also has the cap which you remove to add oil. It seems to go by several different names.
hgeittmann
Longmont, Colorado
05 Passat Wagon
Damn this thread... pulling the head off scares me a little bit, but sounds like it's worth it, and how else am I going to learn... And to think I originally bought the car to save money on fuel and insurance. HA!!!
Mike_M
Phoenix, AZ
Black 2002 Jetta GLS
No need to pull the head off. Just pull off the valve cover, then replace the studs one by one, like I did. Leave the head where it is...it's happy there. :p
Mike
jasonTDI
Oregon, WI
The valve cover. It has an integrated seal that is permanent. PLEASE use a torque wrench to install it. 7 ft lbs only. That is NOT tight.
Mike_M
Phoenix, AZ
The way we did mine was "just a touch more than snug". That sound like 7 ft-lbs?
frugality
Spring Lake, Michigan
none, 2016 GTI
7 ft-lbs isn't much. Pick up something that's about 7 pounds. A gallon of water is little over 8 pounds. If you have a 1-foot-long wrench, you need to apply 7 pounds of force, about as much force as it takes to hold up a gallon jug of water. 7 pounds at a 1-foot distance = 7 ft-lb. If you have a 6" wrench, double the force to the force it takes to hold 2 gallons of water. 14 pounds at a 1/2-foot distance also equals 7 ft-lb.
Mike_M
Phoenix, AZ
Then mine's pretty close to being right on.
hgeittmann
Longmont, Colorado
05 Passat Wagon
Covers, valves, cranks... I don't think my car has any of those... tee hee. Thanks. I'm sold. Why not. My crying son (pictured left) will be soooo happpy when he inherits this thing 15 years from now. HA!
robnitro
NYC area, NY
2001 Jetta TDI GLS silver
I ordered a set of the ARP's, as it sounds fun to install, what size is the triple square and the allen key socket?
80 ft lbs sounds like a lot for an aluminum head... any issues with the head warping from the high torque (w moly lube too, yowza)
Also, what about the retorquing of the bolts after a heat cycle, like driving around and doing it warm like oldpoopie said???
jasonTDI
Oregon, WI
You think 80 is tight do the NORMAL bolt install procedure. WAY tighter than that with the two 1/4 additional turns. It may not be aluminum but you should try installing a crank bolt. You have to hold onto the chassis when you tighten those.
Mahoutsukai
Phoenix, AZ
Just a guess, but ARP seems to be the experts in this business, and they only mention one way to torque down the fasteners. Nothing is ever said about re-torqrquing them down after a heat cycle in the instructions and technical notes.
Mike_M
Phoenix, AZ
Subject to fuzzy memory:
The Allen key for the [valve|cam|head|crankcase|whatever] cover bolts is, I believe, a 5mm.
The Allen key to take off the EGR (which you'll have to do to get to a couple of the rear bolts) is 6mm.
The triple-square is, I think (less sure than the others), 10mm? I'm pretty sure that what I used (mahoutsukai's) is a Metalnerd tool.
Mike
DanEboy
Commack, NY (Long Island)
Jetta GLS 2000 Auto
When replacing studs the head gasket has already been in use for some time and has already been compressed with heat! Retorqueing is more of a concern with a new head gasket and then it still depends on the construction of the gasket. Some manufacturers say retorqueing is not necessary.
Also, on the subject of why head studs may result in increased MPG...
I understand that besides better clamping force the other benefit is by having the stud fully seated in the block you effectively spread out the force on the block thereby decreasing bore distortion. A more round bore makes for a better seal to the rings. And with 19:1 compression even a little better seal should make for more pressure on the top of the piston!
Less blowby better economy!!!
BlakGolf
MTL canada
2000 mk4 golf
we have had to retorque on gassers if we didnt take the undercut option on the nuts. sounds like a interesting subject on a tdi. i had never heard about it in the short while that ive been on the forum
South of Boston
I'm still on the fence on this mod. I've got Sprint 520s, RC3 Euro, OMI, 2.5" exhaust, making about 130/270. I get mod 40s when I drive it like I stole it. Will I really notice a difference?
mwalters
SE Michigan - Have VCDS
Jetta TDI 2013 Tornado Red
What is the right ARP part number for the kit?? :confused: The pic above shows 251-4701 - that is listed to fit Ford Cosworth/Sierra 1.9L and 2.0L 4cyl. engines. There is no kit listed for the VW 1.9L TDI, only for the VR6 and the 1.8T/2.0L 4cyl. That number is 204-4701. ARP's website also does not list a kit for our beloved ALH engine.
I wish you'd quit posting this stuff - you guys are costing me alot of money:mad:
Occams_Razor
Dayton, Ohio
Jetta Wagon, 2003, Reflex Silver
251-4701 is the correct number. It is not listed for the TDI but that number is the correct kit.
mwalters
Thanks! Just ordered it from Summit, but it's still out ouf stock.:mad: Tentative ship date is 3/27/06.
Mike_M
Phoenix, AZ
According to mahoutsukai, probably. He went from low 40s to (probably) high 40s on average, and his power (and mod) level is very similar to yours. You should pick up a few MPG consistently (although, as always, YMMV).
Mike
Mahoutsukai
Phoenix, AZ
Mike
Before this mod I was getting about 44MPG freeway on my 2002 Jetta TDI (Upsolute StageII/Upsolute FMIC/Sprint 520).
On my car with 85K miles, driving an indicated 75MPH (cruise control locked in on this) on a non-altitude changing, relatively straight freeway (Phoenix, AZ to Tucson, AZ and back) I now get 53.3MPG after doing this modification. I now also average 43MPG in the city.
