I could really use some seasoned advice - I am new to the world of diesel.
I purchased my inlaws 96 Passat TDI after my nephew ran with the moderate oil pressure (not zero, the other one) warning on for a half mile or so. I decided to drop the pan, clean out the goop in the pan, replace the oil pump, and check the main and rod bearings. I anticipated 195,000 miles of gunk on the internals, as the externals were...filthy.
Much to my surprise, the pan was spotless, the pickup tube on the oil pump completely clear. Remarkably clean. Hmmmm. I plastigaged the mains and rods and found them all within wear limits, and nothing alarming in their appearance. I changed out the rod bearings and the mains that i could reach, plastigaging as I went, and all seemed great. Not a scratch on any crank journal. I put the new pump in, and when I barred the engine over to check rotation for priming the oil pump, I discovered the auxilliary shaft wasn't turning. A used pulley, some loctite and a new woodruff key, and my oil pressure came right up when I started priming.
The inside of the valve cover was spotless as well, no signs of camshaft damage. I was very optimistic at this point.
I got it back together and after much cleaning and replacing fuel return lines and such, it fired right up and sounded great. 100 psi oil pressure, dropped down after awhile to the 40's. All seemed well.
2000 miles later, I have a "Tack,tack,tack,tack...." sound when the engine comes up to temperature, at idle. Driving it about, it sounds great. No driveability issues, starts easily, great performance, plenty of boost.
So I begin to worry, wonder and investigate....oil pressure starts at 100psi at start but drops directly proportionally with coolant temperature. At operating temperature I have 18 to 23 psi, which goes back up linearly with engine RPM to 80+ psi.
I checked injection timing and the value it was asking for and actual are within 0.2 deg, and nowhere near 2 deg BTCD, just a few tenths ATDC as its calling for.
I opened the valve cover hot, put cam assembly lube on the lobes and fired it back up - no change.
Today I dropped the pan - I feel zero play on any connecting rod (aside from thrust). I popped the #1 and #4 rod caps off to have a look. The cap side bearings were a little scuffed but fairly normal looking. The rod sides are much more heavily worn. I have pix if anyone wishes to see, but my gut is telling me I'm barking up the wrong tree.
I welcome suggestions, torque recommendations on the rod bolts, sympathy and advice. What should I do next?
