trowelbyfar
I have a 2003 vw jetta tdi 5 speed that has an issue with the clutch not disengaging. The clutch pedal action doesn't feel like it has consistent resistance through its travel. Not enough resistance through the first half.
What has been done so far:
- new slave cylinder (FTE)
- new master cylinder (Meyle)
- system bled (Valvoline synthetic dot 3&4)
- new clutch kit (Sachs)
- transmission fluid changed (redline mtl)
Single mass flywheel was installed by previous owner and looks good. Also the clutch fork is not bent and looks good at the pivot ball.
Is there anything else I should check?
