spider_mun
Just had my 2001 Beetle TDI in the shop, "engine light" was on, and I did notice a lack of power, well they say new turbocharger is required. ($2200.00 est). I have had turbos fail (non VW, old Yami Seca Turbo) and I not sure what is wrong with the turbo on the VW, no indications, no oil leaks no noises, without visual inspection (crack or broken blades) what can the OBD-ii tell you? I do have the OBD-II software (vag-com) but my cable is on loan should have by next week. I am shopping for a turbo, I hope to replace myself, The Haynes manual I have says in order to change the turbocharger, the right-side drive axel needs to be removed? Not sure why, unless this is to remove the intercooler. I am an accomplished mechanic, so I am not unfamiliar with this, I maintain two large cruisers (boats) one has Hino Diesels(turbo). Anyone familiar with the New Beetle, and any with turbocharger replacement, any info would would be appriciated to speed up my repair. Seems odd to have to remove the drive axel?
