I get a little too - not enough to see it in my rear windscreen, but i sometimes see it drift into view in the nearside wing mirror when the wind is blowing right. white smoke rapidly turns black though once I get throttle happy.
Well I used to see quite some white smoke on start up also. Felt it was from the fuel or something till I lost my turbo!!
Now I know better!! White smoke is usually from Oil leaking through the exhaust turbine seals. I guess you should brace up depending on how bad the white smoke is. Turbo replacement in view!
It could be either unburnt fuel or perhaps oil in the exhaust from the turbo. Normally I would say fuel. And since you are in a cooler climate (35C here today), the puff of white could be because one of the GPs isn't quite hot enough, ie burnt out.
