Old June 29th, 2020, 20:33   #1
santacll
Default camshaft replacement
So i've started reading through the process, from some of the info i have gleamed it looks straight forward, out with the old in with the new... but then i see a comment that the injectors need to be reset... dial gauge and fancy rotation process....
Is everyone who replaces their BHW camshaft also doing this? or if all we do is pull the rocker shaft, the may not be necessary?
comments please.
c.l.
IBA12929. 03r1100s, 09boxster, 74norton
nothing clears the mind like 3 tanks of gas at speed.
santacll is offline   Reply With Quote
Old June 29th, 2020, 20:40   #2
Mozambiquer
Mozambiquer's Avatar
I would definitely recommend it.
Sent from my S60 using Tapatalk
Mozambiquer is offline   Reply With Quote
Old June 29th, 2020, 22:21   #3
Will27
No dial gauge needed
http://forums.tdiclub.com/showthread.php?t=306911
Will27 is offline   Reply With Quote
Old July 2nd, 2020, 09:08   #4
zzdiesel
I used the BEW kit which Bora sells. Supposed it is supposed to last longer with very little reduction in power.
I also used the break in oil and procedure that they recommend.
zzdiesel is offline   Reply With Quote
Old Today, 06:47   #5
wrx603
So you don't need the dial. I just did my lash with one and the duration is so long you can look at the cam while ur doing it and get it 100%. That said, it does take some of the human factor out of it.
wrx603 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Camshaft Replacement desimir TDI 101 3 January 7th, 2020 08:33
Camshaft replacement alireza57 VW MKV-A5 Golf/Jettas 32 December 13th, 2018 23:45
Camshaft Replacement Volunteer TDI 101 0 May 18th, 2018 17:01
Camshaft Replacement kpaske West Coast Canada/USA 3 March 16th, 2015 19:14
Camshaft replacement help girvil VW MKV-A5 Golf/Jettas 3 June 17th, 2010 07:54
Page generated in 0.13448 seconds with 13 queries
[Output: 67.53 Kb. compressed to 59.74 Kb. by saving 7.78 Kb. (11.52%)]
