Old June 28th, 2020, 13:10   #1
ken.fresno-tdi
Default No start AHU mystery after running great
back story: I did a AHU TDI transplant into Eurovan over a year ago. 150K on engine and professionally rebuilt 10mm injection pump. Great running; 4000 trip last summer and almost daily 150 mile r/t in past month to go from Fresno to Yosemite where I am helping build a cabin. Some problem with boost control (separate thread) but generally very nice running van. Three days ago started up fine but died after 5 or 6 seconds, still in driveway. No restart though seemed like it wanted to - engine would catch and stumble but not really go, and then just crank. First made sure 109 was good and that stop solenoid was clicking. Glow plug light works. I have a BEW in-tank fuel pump installed that pushes diesel through fuel filter but still bypassed any possible fuel filter clog or air leak by sticking both diesel lines into jar of diesel. Still no start- wants to and stumbles then dies. Looked for codes and found P1248 - timing issue? Checked to make sure timing was good - all checked out but IP was a bit off center so decided to retime the whole thing. Retimed using proper tools and made sure all was EXACTLY right - flywheel, camshaft, IP all on center and IP in middle of rotation. No sign of start at all after priming several times/cracking IP lines properly. Then I remembered when I first installed engine I had timing problem and had to advance IP sprocket one tooth to get engine running. Strange but apparently documented and true. Redid timing with IP sprocket advanced one tooth. Result is back to original condition - fires up for one or two seconds, stumbles, but not quite starting. Aaghh! Now thinking back to original issue three days ago where it started and then just stopped after running for a few seconds I wonder if some electrical issue in IP is the problem? fuel delivery seems fine. Air intake is fine. timing seems fine. N108 valve? never touched it before... Other things to check? I have VAGCOM and am not afraid to use it but without starting engine can't really check dynamic timing or other possible issues. Where do I go from here? Thanks for any thoughts!
ken.fresno-tdi is offline   Reply With Quote
Old June 28th, 2020, 13:13   #2
Mozambiquer
Mozambiquer's Avatar
If you loosen the injector lines does it spray fuel out when you crank it?
Sent from my S60 using Tapatalk
Mozambiquer is offline   Reply With Quote
Old June 28th, 2020, 13:22   #3
ken.fresno-tdi
definitely. each one loosened plus return line loosened at end of IP during each attempt to bleed fuel lines. evidence of sprayed fuel throughout engine bay : <
Old June 28th, 2020, 13:32   #4
ken.fresno-tdi
I should also add that during attempts at restarting I physically advanced IP to most advanced position (rotated toward engine) and most retarted (rotated toward radiator). When most advanced it definitely did not catch at all; when most retarted it comes closest to starting. This made sense to me since IP is advanced one tooth.... But when IP was on properly (not advanced one tooth) and physically rotated most advanced it still wouldn't start.... and battery and starter are almost new; good cranking speed with battery charger on overnight to ensure full amps.
Old June 28th, 2020, 19:52   #5
KLXD
I wonder if the advance piston is stuck at full travel since it wants to start when you retard it. I didn't catch where you fully retarded it when you timed it straight up. Only when advanced a tooth.
I doubt it since rotation of the shaft would want to push it back to the normal retarded position. I think.
N108? Should be able to hear it clicking by applying 12V to it, not by turning on the key. Other clicks going on when you do that. Or remove the guts to be sure. Just a spring and plunger.
At this point I would try running it from a bottle to eliminate the possibility of a fuel line obstruction.
As far as timing it a tooth advanced is concerned, I've had to do it and not do it on the same engine. I think it has to do with how hard I want to try do get the slack out of the new stiff belt that has built in bends from shipping.
Saying no to gas for 25 years:
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
KLXD is offline   Reply With Quote
Old June 28th, 2020, 22:06   #6
ken.fresno-tdi
thanks for the ideas. I'll work on them tomorrow, especially related to fuel. I just read through the post you and Mozambiquer and others helped diagnosing kurtzl's no start issue (AHU - Air in fuel system) and gave me some more ideas too. Yes, I too am wondering if there is some kind of fuel starvation/blockage issue - there is fuel coming out of loosened injector lines but perhaps not enough. I've dealt with hard start/no starts over the years (owned about 5 AHU engines since 06) but I can't recall one where I hadn't altered something on the car to cause the problem. Also, in rechecking VAGCOM codes it did throw a 01237 Fuel Shut Off N109 open or short to ground at one point while trying to start it but I've jumped the N109 solonoid straight to the battery several times to make sure it wasn't the issue with no difference, and the code didn't return after clearing. The 109 relay otherwise seems fine (looking for my spare to make sure).
Old June 29th, 2020, 12:58   #7
ken.fresno-tdi
so I got a fuel container and hooked up a gravity flow fuel supply directly to the pump, with return line bypassing the fuel filter T. Tried starting and same issue - starts for a second or two and then dies, again and again... Decided to take out the N109 solenoid since I had the code and the clicking sound did not seem strong when hooked up directly to 12v. To do so I removed all the injector lines first to try to get access to the N109 without removing the top half of the IP. No luck - very tight and you can't get a 24mm socket or wrench on it. So I took off the top half of the IP, carefully making awl marks on top and bottom to match when I put it together again, and keeping everything very clean. I actually didn't have to take off the top half of the pump, just loosened all the bolts and pushed it as far to the left as possible to give access to a 24mm socket. Removed the N109 valve and tested it on the bench. I could not get any response from the solenoid with 12V on the wire end and a ground wrapped around the threads. Tried the same on two old spare solenoids I had laying around and same issue. I assume I should be able to get some kind of response from a working solenoid...?! Anyway, it kind of made me hopeful because if that is the problem I can temporarily make do by removing the spring and plunger and just kill the engine with 5th gear and clutch out. I removed spring and plunger and put N109 solenoid back, aligned and tightened all the IP bolts, and reinstalled the injector lines. Used a mityvac to fill the IP with fuel and pull fuel all the way through to the return line. Cracked the injector lines and cranked for a while to remove air and then tightened things up and cranked. Nothing. Not even a hint of wanting to start. checked codes in VAGCOM and got the following:
4 Faults Found:
00532 - Supply Voltage B+
27-00 - Implausible Signal
01237 - Fuel Shut-Off Valve (N109)
31-10 - Open or Short to Ground - Intermittent
00626 - Glow Plug Indicator Light (K29)
31-00 - Open or Short to Ground
00668 - Supply Voltage Terminal 30
The N109 error makes sense since it wasn't even hooked up (since I took it off) but the others look like the 109 relay isn't working. But the glow plug light comes on for a second so I assumed it was. Or perhaps a bad ground? Now I'm thinking one of three things:
109 relay is bad and I'm being tricked into thinking it is good because it still mostly supplies power to glow plug light
or
I have a bad ground - since I put the whole engine together in the van I should remember where the grounds are, but I'm thinking the ones that come off the large circular connector are the ones I should be checking, since most all the engine wiring goes through there... correct??
or
when I carefully moved the top half of the IP over to the left to make way for the 24mm socket on the N109 I accidentally pulled it up to much and dislodged the IQ adjuster from the sliding mechanism below, or when I was realigning the top half of the pump I just lined up my scratch marks wrong (though they look exactly right). I've done the hammer mod several times and replaced seals on the top half of an IP so I know the basics of what to be careful for but I also know that is an extremely sensitive piece of machinery.
Thoughts? So frustrating!
Old June 29th, 2020, 14:20   #8
ken.fresno-tdi
I went ahead and bought an new N109 solenoid ($35 from vwpartsplace.com)and a 109 relay (need one anyway as a backup) and will look for bad grounds while waiting for those to come...
Old June 29th, 2020, 16:43   #9
ToddA1
Fuel Economy: Dismal
If the GP light works and you’re able to pull codes, I doubt it’s the 109. Jumping 12v to the stop solenoid should back feed the circuit, bypassing the 109.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old June 29th, 2020, 21:24   #10
Jetta SS
Jetta SS's Avatar
TDI(s): '98 Jetta
Fuel Economy: 48
I seem to recognize some of those codes from a no start I had. I had forgot to reconnect the IP electrical plug after doing some work. Maybe take a close look at the ip plug/wiring.
Jetta SS is offline   Reply With Quote
Old June 29th, 2020, 21:49   #11
ken.fresno-tdi
thanks. will do.
Old June 30th, 2020, 03:51   #12
Mongler98
Wireing harness. Sounds like something came unplugged or broken. Probably kn the ip harness. Mark6 has a similar issue. Turns out broken wire.
Old June 30th, 2020, 20:06   #13
ToddA1
Abacus, always finds broken wires, inside the loom. It’s worth investigating.
-Todd
'97 B4: Stock
Rabbit build
Old July 6th, 2020, 13:41   #14
garciapiano
Those are the exact codes you get when the injection pump is not plugged in. Sounds like a fault in the wiring loom somewhere.
garciapiano is offline   Reply With Quote
Old Yesterday, 08:21   #15
ken.fresno-tdi
Update on my no-starting issue on 98 AHU. Reminder that the engine had been running great and then suddenly no-start in driveway. Appreciated responses that related to the several fault codes (post #7) that seemed to indicate an electrical problem. I realized that those codes had only occurred one time so I made sure the two IP connectors were seated well and tried starting again. Checked fault codes on VAGCOM - none at all. Then I waited till I received a new 109 relay and new fuel shut off solenoid. Put those in place this morning and then:
- made sure that the IQ adjustment pin seated in correctly when putting the top half of the injection pump back on and tried to make sure the scrawl marks were lined up exactly right on the top and bottom half of the IP.
- removed the injection lines from the pump and put down paper towels to catch diesel as it squirted out of the pump.
- Set up 1 gallon container of diesel from above engine directly gravity flowing into IP.
- Trickle charged battery overnight to make sure it was strong.
-turned key to on position and then touched wire from starter solenoid to battery so I could watch what was happening to fuel coming out of IP.
Result of cranking: no fuel coming out of IP injector ports, or, to be more accurate, a dribble that continued after ending trying to start - from, I assume, gravity fed fuel lines.
- Checked VAGCOM codes. Nothing.
-glow plug light comes on for a second and goes off - normal.
- Directly hooked up 12V to 109 fuel shut off solenoid and tried starting.
- Still no fuel coming out of IP injector ports
- Still No codes at all
So now I am stuck again. N108 solenoid? I assume that the solenoid could be bad even if VAGCOM says that the electrical connection is o.k.? Something else blocking fuel inside IP? I've never gone further than changing seals on an IP and doing IQ adjustment but assume that IPs just suddenly go dead. What am I missing?
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ken.fresno-tdi
Huge cloud of smoke, limp mode, then running great? misternoggin VW MKIV-A4 TDIs (VE and PD) 3 February 22nd, 2018 14:33
AHU Chip Mystery c3k VW MKIII-A3/B4 TDIs 9 June 10th, 2015 17:46
Was running great, then lost power Clydetdi VW MKIV-A4 TDIs (VE and PD) 5 July 16th, 2013 21:04
Koni is running a great sale! VailPowder Vendor & GroupBuy items for sale 53 March 27th, 2012 14:22
low power (long running mystery problem!) cocteau104 VW MKIV-A4 TDIs (VE and PD) 13 December 4th, 2005 21:57
Page generated in 0.17338 seconds with 13 queries
[Output: 134.31 Kb. compressed to 113.18 Kb. by saving 21.13 Kb. (15.73%)]
