Old February 21st, 2007, 07:58   #1
ski98033
TDI(s): 2002 VW Golf
Default TB Tensioner Broke, but looks like I am ok
Hi,
My 2002 TDI started sounding like a large truck on the freeway. I immediately started coasting and got off the freeway at the next exit (about 5 minutes with minimal load on the engine) before I could turn it off. Had it towed to the place where I purchased it and they diagnosed a bad tensioner part (they had just done the 80K replacement of TB, Tensioner, and water pump). They replaced the part and it runs fine now. Question for the group is can something like this cause a long term problem or if the engine runs now am I ok.
Thanks,
ski
"When we try to pick out anything by itself, we find it
connected to the entire universe" John Muir
ski98033 is offline   Reply With Quote
Old February 21st, 2007, 08:02   #2
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
You're screwed. Sounds like that mean the valves were contacting the pistons. The tensioner COULD have failed but it's unlikely unless they cammed it around from the bottom or didn't get it locked in the hole.
I HIGHLY doubt they have a vagcom and lock down tools so the job at best is marginal.
DEMAND they cover any valve train related failure for the next 10K miles. By then something will break if it's going to. I'd go elsewhere and have the cam pulled and look for lifter damage too. VERY PROBABLE.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old February 21st, 2007, 08:04   #3
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
Kudos on your quick response. You may have saved yourself a big bill.
Does the car run as it did before?
It may appear to be OK, but if the valves made contact with the pistons at all, they could be weakened and may fail prematurely.
I would ask the place that did the TB work to extend the warranty in case this failure does happen in the future.
Do you know if they replaced the engine mount bolts when they did the TB job? Is this a VW dealership or an independant shop?
-tom
autos: 15 Volvo V60, 14 BMW 535d xDrive
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old February 21st, 2007, 09:24   #4
weedeater
Fuel Economy: 54/43/38
What he said.
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Old February 21st, 2007, 09:57   #5
LanduytG
LanduytG's Avatar
I have seen one time where nothing made contact. But what I would do is have a compression test done. That will let you know if you have any bent valve. I have seen a couple of times that the valves looked OK but when you took them out and did a run out with a dial indicator they were bent.
Greg
TDI CLUB Supporting Vendor
Check out our Online Store
Fumoto Oil Drain Valve
Amsoil Synthetic's Dealer Wholesale Pricing
1-888-306-4255
LanduytG is offline   Reply With Quote
Old February 21st, 2007, 13:50   #6
chromeBuddha
chromeBuddha's Avatar
Fuel Economy: 47 mpg @ 75 mph
Compression test, pull valve cover and check for deformation of the lifter/cam contact surface.
As JasonTDI said, there is no reason for the tensioner to fail if the just did the job properly. If they didn't do it right the first time, it seems unlikely they will get it right the 2nd.
2002 Golf TDI, 5-speed, 2-door
White w/ Tan interior (get the Scotchguard!!!)
47 mpg @ 75 mph
"El Bonbon" - The Marshmallow
chromeBuddha is offline   Reply With Quote
Old February 21st, 2007, 13:54   #7
alphaseinor
Do a compression test when cold, then when hot.
You can get a compression tester for diesels at harbor freight for like $30.
Good luck... I helped replace an engine that had a failed tensioner. the engine never ran right when cold. even with a head job
alphaseinor is offline   Reply With Quote
Old February 21st, 2007, 20:49   #8
ski98033
Thanks for the comments. The car runs just like before with possibly one exception (not sure if I am being overly sensitive or not). The exception is I smell diesel for just an instance when I get out after a turning off the engine and I do not remember smelling the diesel before.
I already have a 5.5 month warrantee left on the car. I bought it from an independent dealer who specializes in diesels (mostly VW TDI's) so I am pretty sure they have the tools. They also have a good repuatation in the community. I am the second owner and they had all the paperwork from the first owner for all the maintenance. I will check and see if they did a compression test, visual inspection, see about extending the warrantee.
Old February 22nd, 2007, 02:24   #9
LanduytG
LanduytG's Avatar
Yes you can check them but it will not tell you if the valve is bent, only that the valve was hit.
Greg
1-888-306-4255
Old February 22nd, 2007, 13:38   #10
alphaseinor
you can take off the valve cover, and you should be able to see a dent in the lifter, if it's a hard hit it will have spiderweb cracks on the chrome surface. if either one of these is there, then you have a valve that is a ticking timebomb.
Old February 26th, 2007, 08:49   #11
chromeBuddha
Having heard the horror stories of the valve heads later detaching due to unseen internal damage, I would replace any valve that had piston contact, even if it measured 100%. $12-20 x 4 sounds a lot better than the potential of replacing lower end components of the valve head jams between the piston and the head at speed...and redoing all the head work...
Greg
47 mpg @ 75 mph
Page generated in 0.15297 seconds with 10 queries
[Output: 103.02 Kb. compressed to 86.86 Kb. by saving 16.15 Kb. (15.68%)]
