202k mi, 2003 Golf TDI ALH
Stock, besides Koni SRT.T "Orange" dampers.
A bit ago I started hearing a noise from what seems like the right side of the car, getting worse and worse until now it's louder than the engine while on the highway...
It starts making noise above ~40mph, and is vehicle speed based (aka engine speed doesn't make a difference, transmission in any gear, also neutral doesn't change the noise). The noise (kind of a low grinding noise, almost sounds like a vibration but I'm not feeling anything) gets louder when you turn the car to the LEFT, and goes away when you turn the car to the RIGHT. It also has a braking noise/wobble under mid-hard braking from speed (also seeming to come from the front right)
There is A LOT of dust/ crud on the front right wheel, and not on any others, all of the brake pads and disks having been changed recently.
Now, I mis-read this as a front right wheel bearing, and tore the car apart and got the hub off to change the wheel bearing. Once that was changed (only forgot the retaining clip... once), I got the car back together (also changed the ball joint since I was in there). No change, same symptoms despite the new bearing and ball joint.
So.. I'm stuck, and frustrated. Did I just get it backwards, and need to do the left bearing instead? Is there something rubbing on the driveshaft or the wheel (I need to go looking)? Other things I may not have thought of?
Open to ideas, and learning. Thanks in advance!
-Ryan
-Ryan
