So, during trouble shooting my inoperative a/c for the 4-dr, I found that there was sufficient refrigerant (well, pressure-wise anyway), the compressor clutch works fine, the compressor is commanded on and off, but won't stay on for more than a few seconds, and both fans will not run.
Yes, the fans are fine. At one point I was going to pull the coolant temp fan plug at the radiator, but true to most weather-sealed connectors, I was unable to get the plug out. My fingers just aren't that strong and there's too much in the way to get a screwdriver in there.
So I decided to re-check the fuse. It looks perfect. The fuse, anyway, so I figured it would be a good idea to pull it and check closer.
It would. NOT. pull. out. Kinda like the weather sealed plugs, only this thing still held even after destructive pulling with a pair of pliers. The one blade came out, but the other, the one on the load side, refused. I was finally able to get it out and found the blade covered with a black substance which greatly resembles the black plastic surrounding the socket. Or rather, the plastic that used to be in the shallow crater surrounding the now pulled blade. Looks like it heated enough to melt the plastic and foul itself.
I was going to replace the whole fuse carrier on top of the battery, but the only spare I have comes from an auto-transaxle car, so it is missing the 5th fuse for the coolant warmer plugs. Sigh...
Anyway, a new fuse and now the coolant fans are running again. I'll test it tonight and see if the a/c problem is corrected.
Update: it worked! Cool air, just in time for summer. Or, what passes for summer way the <bleep> north.
Cheers,
PH
