Reprint? Damn near plagiarism...lol.Sorry, but there's nothing new to the TDIClub in this report. The lubricity chart is a reprint of the Spicer Report, from 2007, which has been hotly debated/discussed on this forum for more than 2 years.
Too bad...I was hoping you had discovered an updated lubricity test!!
I think this was more down to a LB7 issue than an additive. It has been pretty well documented that engines incorporating high pressure fuel systems have suffered failures due to a combination of poor fuel quality and extreme requirements by the EPA on emissions. To get around this manufacturers developed high efficiency fuel systems which demand good fuel lubricity to function.I ran two cycle oil in my diesel in my LB7 Duramax in the hopes of increasing the life of the injectors. It did not. In fact they failed just as fast if not faster than the factory installed set of injectors. My conclusion on 2 cycle oil added to diesel fuel is snake oil.It was a waste of money and I will not do that again.
Yeah it was pretty much an LB7 issue. Many thought it a lubricity issue and others swore that it was filtration. I did it all and yet had multiple failures. One cannot depend on additives to fix design faults. I have run many additives on and off in various diesels I own. I cannot say bad nor good on their usages.I think this was more down to a LB7 issue than an additive. It has been pretty well documented that engines incorporating high pressure fuel systems have suffered failures due to a combination of poor fuel quality and extreme requirements by the EPA on emissions. To get around this manufacturers developed high efficiency fuel systems which demand good fuel lubricity to function.
There are hundreds if not thousands of older Diesel engines who run 2 cycle and/or new engine oil through there fuel systems with good effects. I know that some drivers of International Navistar 6.9 and 7.3 IDI engines are increasing Injector life due to adding lubricity to their fuel tanks
Doesn't look all that special just based on the MSDS.Try Hammonds lubribor aprox 1/8oz per 10 gallon. adds lubricity to ultra low sulfur diesel. It complies with federal low sulfer content requirements. I have been using Hammonds additives for years.
+1 If you're going to use 2-cycle oil, that's the one to get. Don't be tempted to buying an expensive brand like QuickSilver or Penzoil thinking they'll work better. They won't. You'll just be wasting money, imo.The 2-stroke oil should generate higher BTU in combustion vs. B100 so more power is an added benefit
I have used this stuff for years. Never had a pump failure due to lubricity issues even at high rpm on a 12mm pump head..
And it depends on which 2 stroke oil is used. There are two main types of 2 stroke oil, and only oils marked TCW3 (or TCWIII) are ashless and burn completely. I've run many 10's of thousands of miles in my 6.0 PSD with TCW3 oil mixed at 1oz/gal. It quiets the engine significantly. I switched to Opti-Lube summer blend for trips over 2000 miles. Opti-Lube useage ratio (2 oz/30 gal) lets me carry enough (2 qts) for a 10,000 mile trip where I would need to carry 5 gallons of 2 stroke oil. Both give similar results forthe 105K I've used them.I think this was more down to a LB7 issue than an additive. It has been pretty well documented that engines incorporating high pressure fuel systems have suffered failures due to a combination of poor fuel quality and extreme requirements by the EPA on emissions. To get around this manufacturers developed high efficiency fuel systems which demand good fuel lubricity to function.
The max recommended dose for PS is 8 oz per 12.5 gallons. The other [FPPF] is just more cetane boost.That's a lot of additives.
Actually, since his post is so unbelievably convolute, it appears he has read too many posts and is as confused as the rest of us.You didn't search very well.
