Well, CEL is on and the GP light is flashing, as well as reduced power on my 00 Golf. Pulled the codes and there is a "17655 Lift Needle Sensor (G80) open or short to +" code.
Cleaned up the area and checked the wiring to the #3 injector. All seems OK, no obvious broken wires or the like. And when I test the resistance of the wires to the sensor on top of the injector it reads open (eg infinite resistance). So I will look once again for possible breaks in the wires that don't show thru the insulation, but I suspect the sensing coil in the injector is toast.
My question is what is the right way to "fix" this? I assume I need a new #3 injector with sensor, new copper washer for it, new copper washers for the return T fitting. What else? Would it be best to take all the injectors out have them cleaned and balanced? New nozzles (300K miles on them).
Guidance here?
Guidance here?
