Dan, I wasn't able to locate page 38/3 in the Bentley, rather my book stops at 37-60 Automatic Transmissions and then continues onto 39-1 Differential and Final Drive, any section numbered 38 is missing. I found section 19-7 and 97-3 to help troubleshoot the thermo-switch/FCM and the fuse panel, respectively. I checked out fuses S164 and S180 and verified they're good, so that's good news. Cleaning the terminals would have a been a good idea for S180, though, I'm sure where you get a
terminal cleaning tool for fuses, any idea? Let me know if there are other helpful sections.
Until I popped the hood of the car, I was confused by the orientation of Image 0024245 in section 19-7 of FCM.... Now I see that it's under the battery trey (Google images helped affirm this too). Being that I just lost daylight, I will get under the car tomorrow and drop my skid plate and be able to get access to the FCM.
Thanks for the info about galvanic corrosion, I recently added a
DieselGeek Panzer Skid Plate this past October 2015 for engine protection. The previous owner said the OEM cover had fallen off two winters ago and as such drove the car without it.
Is the
FCM 14 pin
connector on the left or right? I'm assuming the left based on watching this
mechanic check for continuity across the relay. Though, I'm assuming the FCM will be the same pin configuration for my TDI as a VR6, let me know if this assumption is wrong.
Lastly, appreciate ya expounding on the root cause failure and way to fix the fans.
