vintage red matthew
First of all let me know if this is not the right place for this.
Hi, everyone.
I'm a new TDI owner and new to this forum.
I have a 2004 Beetle, diesel (of course), manual transmission. It has a few problems but I only paid $500 for it because someone hit a deer with it so I can afford to put some money in it. No serious damage but I replaced the windshield. I may replace the hood later if I can find one the right color at a salvage yard. There are a couple dents on the roof that I am going to live with.
I have a lot of questions but I am going to try to research as many as I can myself however I do have a couple issues that need attention. The CEL is on and when I put the scanner on three codes came up. I don't have the numbers in front of me now but I can get them.
Two of the codes said basically the same thing. Low turbocharger pressure. My limited preliminary research on YouTube suggests that it may be the diverter valve. I saw how to check for oil leakage through the electrical plug. I plan to do that soon but my lift isn't working and I am being slowed down by an injured foot but I can drive it up onto ramps. I saw the valve for sale on eBay for about $35. I would rather buy local to be sure I am getting the right part but the local part stores can't find a listing for it. Is there a different name I should be asking for? Any advice would be appreciated.
The other code that popped up was for low coolant temperature. There is no gauge on the dash but the heater works good so I'm thinking it's the sensor. The sensors that I'm seeing have a D shaped plug with 4 pins. I can't find a plug like that on my car. When I look at what I'm pretty sure is the thermostat housing I see three separate sensors with one wire each. Is the sensor somewhere I'm not looking? Since this is the first year for the PD motor could this be an early version?
Thanks in advance.
Hi, everyone.
Thanks in advance.
