sinc
I've recently added a few things to my TDI, lets start off first by saying I am far from a mechanic, I'm just some d****** who likes to spend lots of money on his car like its an addiction... err it is I guess an addiction
So this is a purely a post of what I did since some members have asked to see whats involved and by no means a complete DIY blah blah blah use this info at your own risk.
Links to where I got my information from:
Climatronic Swap (has links to other sites on it): http://uk-mkivs.net/forums/t/332130.aspx
Half MFA Install: http://forums.tdiclub.com/showthread.php?t=48366
Glovebox AC (see post #20): http://forums.tdiclub.com/showthread.php?t=80023&page=2
The install is being done on a 2001 Jetta TDI, reason for this whole idea was because of a trip to h2oi in Ocean City 2 years ago. My heater box broke en route, ac stopped working and it was only blasting heat for the rest of the trip. diagnosed it to a broken blend door and since thius was my summer car I just bypassed the coolant to avoid the heater box and bingo, no heat but ac still worked. Last fall got cold so I looked for a solution this winter. Found a sweet deal on a complete climatronic swap and bought it long before I knew what was involved.
I apologize in advance, only have a cell phone camera and I didn't take as many pics as I should of.
I had the wiring loom out all winter matching wires up to diagrams and pin outs from the link above. After I got that all straightened out I started.
You need to go from this:
To this:
This was the longest process, removing all the interior bits and the dash. Seats out of course, can't imagine doing it with them in. At this point I already had the old heater box out, note I got frustrated and ending up bending a part to the left of the passenger airbag to get the box out, it is big and I don't know how you'd take it out without removing the whole dash bar. But the peice bent back fine and so far no issues haha. Also took this time to clean up my wiring disasters from previous projects, everything is zip tied to the oem wire harness so it looks clean, alot more than it did lol.
The old box on the left, climatronic on the right:
My box was the t17 and t12 loom.
Next was wiring up the loom.
Some of the existing wiring was still usable so I cut and spliced instead of running new wires. They were all for the t17 connector, pins:
1 to Fuse 25
3 to T10/8(orange connector in plenum)
5 to Fuse 5
10 to any illumination wire
So that saved some time.
Next I wired up the sunlight sensor:
Pin 2 went to pin 8 of the t17 connector
Pin 3 went to pin 8 of the t12 connector
Pins 1 and 4 were unused.
The outside temp sensor, this is the connector wired up to be put in the rain tray:
This is where I mounted it in the rain tray, just used the wiper linkage mounts on the passenger side, the one closer to the ecu.
Only 2 pins on this so,
Pin 1 went to pin 5 of the t12 connector
Pin 2 went to pin 8 of the t17 connector(same as the sunlight sensor)
Finding the orange connector in the plenum was a challenge, I ahd no idea what or where to look for, eventually it was found on the driver side of the rain tray under the wiper linkage and motor:
Then from the driver side under the dash I discconnected all the relays and pulled that appart completely so I could get at this connector better:
Pin 9 of this connects to pin 4 of the t17 connector
Pin 7 goes to pin 12 of the t17 connector
To this:
1 to Fuse 25
5 to Fuse 5
