jettdi2000
I have a Jetta 2000 TDI, 287,000 miles I was getting a misfire code via VAG-COM on cylinder #2.The engine was running very rough I pulled the valve cover off and checked the clearance from the cam lobs and lifters (lobs in the up position). I found the clearance between the lob and the lifter for the exhaust valve for cylinder #2 in excess of 1/16 of an inch should be ~8K of an inch. So I pulled the head and had a valve job done, a lot of carbon was found in each intake. Cylinder #2 had diesel fuel in it. The cylinder walls looked good and the pistons when brought to TDC looked good. I cleaned the injector outside tip by using a cloth attachment in my bench grinder, was this good for my injectors?
I put it all back together and I still was getting a solid misfire code on cylinder #2, the timing looked good. I pulled the glow plug for cylinder #2 and it was wet. I then swapped the injector cylinder #2 with cylinder #4 and started the car, I am getting the same rough running condition but now no misfire codes. I checked the glow plug in cylinder #2 and it was dry, cylinder #4 was partially wet. So do you think this could be an injector problem? And did I damage my injectors on the way I cleaned them?
Note: New turbo put in 5K miles ago, intake manifold cleaned, used new stretch bolts for head, new head gasket. Injector pump never changed but has always worked. Also have used veg oil in this car from 100K miles to present, have grease car kit installed, I think this is why my injector pump has never gone out.
