Old October 17th, 2017, 16:51   #31
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
A little more engine engineering for those interested. It's no big surprise that a 3.9 L 4BT develops rated power at "only" 2400 RPM (9.52 m/s mean piston speed) and the 1.9 TDI at 3750 RPM (14.875 m/s), but do you really know why? There are many factors why these two engines develop their rated powers at RPMs that they do, but many parameters scale with the very important mean piston speed (MPS, eg. in-cylinder turbulence, swirl intensity, port flow velocities, etc.). We could take the analysis further. The upper limits of MPS - high-20s m/s in F1/Cup engines, into the 30s m/s for Top Fuel drag racers, are dictated primarily by tribological considerations (maintaining an oil film in the piston ring-cylinder interface) and tensile mass forces taken up by the pistons and connecting rods.
If we set a criterion to limit kinetic energy in the reciprocating group to be roughly constant, which would translate to strain energies that the rods have to take, then the disparities of MPS between say a 4BT and an ALH TDI almost disappears.
Kinetic energy is proportional to the mass times velocity squared.
Mass is proportional to the cube of a characteristic dimension, I'll use bore diameter d here.
So, the kinetic energy is related to d^3*MPS^2.
With the criterion of constant kinetic energy, there results a relationship of bore diameter vs MPS as
MPS is proportional to d^(3/2).
Now let's plug in some numbers:
TDI bore: 79.5mm
4BT: 102mm
Taking the TDI as a baseline with MPS = 14.875 m/s,
14.875 *(79.5/102)^(3/2)=10.23 m/s, which is pretty close to the value of the 4BT's MPS at rated power. The remaining difference can be attributed to the 4BT being designed for heavier duty durability than a TDI.
The take home message here is also that it is not realistic to have a 4BT rev to the same RPM as a TDI, but one can go further to say that it is comparing apples to oranges even to match MPS. Rather, there is a physics-based rationale to relate and scale MPS between engines of different sizes using energetic or mechanical strength criteria.
Old October 18th, 2017, 00:55   #32
mk3pd
TDI bore: 79.5mm
4BT: 102mm
I don't understand what bore diameter has to do with mean piston speed?
www.rosten-performance.com
mk3pd is offline   Reply With Quote
Old October 18th, 2017, 11:05   #33
Yucca
Apart from Andy2, I have not seen any 400+ HP or even 350+ actually realized in a VE, even though in theory it's possible (I have even done the calcs).
We have had many +350bhp VE setups in Finland. My 388bhp ALH is one example
https://postimg.org/image/ohhm3rdif/
- 1.9ALH Block with H-beam rods
- Ported head from npsheads.com
- Custom CAM
- Borg Warner S356V
- HFLO-X 0.341 Nozzles
- Stock 11mm pump
- Tdituning.fi tune
Engine is now in my Chopped Lupo 3L for Standing Miles.
Yucca is offline   Reply With Quote
Old October 19th, 2017, 05:23   #34
vtpsd
Fuel Economy: 45mpg avg
Awesome idea, I hope it pans out. I don't have much to add, other than I am a huge fanboy of diesel tractor pulling. I think if you are allowed to run an intercooler, you absolutely should! I see a lot of guys with "hot farm" tractors that do not, but all the guys that run the best do use them. If they are allowed, you would be crazy not to run it along with water/meth. (only water injection is allowed here in VT).
current: 03 jetta wagon (pp520, malone stg3, straight pipe), ford tractor with saab turbo, Snarling Audi 90q AHU swap (holset he211w, 32psi, race 520's)
past:11 second audi 90 20vt monster, 20vt swapped audi 90 winter beater, 10vt swapped 4kq with efi and many many other 5 cylinder audis, and a few 1.8tq's
vtpsd is offline   Reply With Quote
Old October 19th, 2017, 07:21   #35
TDIpuller
We can run them, I just don't know if it would do any good without having much vehicle speed? We don't go much slower than the big tractors, so maybe it's still beneficial?
TDIpuller is offline   Reply With Quote
Old October 19th, 2017, 07:42   #36
vtpsd
I think it still would be beneficial. Construction equipment and farm tractors still have intercoolers. Its still going to dissipate some amount of heat, even if you are moving slowly.
Old October 19th, 2017, 08:05   #37
vanbcguy
vanbcguy's Avatar
A radiator standing still in the corner of your bedroom still heats the whole room. Ideally you want lots of airflow but even just plain convection will eat a bunch of heat from an intercooler.
Sent from my LG-H873 using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old October 20th, 2017, 09:07   #38
Jetmugg
TDI(s): None
Air-Water intercooling allowed?
Jetmugg is offline   Reply With Quote
Old October 20th, 2017, 09:13   #39
Jetmugg
TDI(s): None
Also, even though this is a VW specific forum, have you considered a Mercedes OM604? If that engine fits within the displacement limit rules for the class, it's worth a look.
Steve.
Old October 20th, 2017, 17:26   #40
TDIpuller
Yes, we can do pretty much anything we want. My limiting factor is space to fit it and weight. Considered it though also
WTB: Turbo for 350+hp rosen TDI Private TDI Items for Sale/Wanted 2 December 25th, 2011 08:01
Alpina B5 350-hp diesel German_1er_diesel Non VW Group Diesels 4 September 25th, 2011 09:53
VW diesel powered mini pulling tractor TDICADDGUY TDI Power Enhancements 19 October 8th, 2010 03:36
TDI in a tractor pulling tractor? JD Steve TDI Motorsports 35 June 21st, 2007 21:49
200 hp/350 lb-ft possible? BIGJOHNO TDI Power Enhancements 27 July 3rd, 2001 23:16
Page generated in 0.16215 seconds with 11 queries
[Output: 102.74 Kb. compressed to 88.34 Kb. by saving 14.40 Kb. (14.02%)]
