DuctTapeFan27
A couple of weeks ago I was coming home after work and shifted into the wrong gear causing the engine to rev past 4000 rpm. It started running horribly and smoking like crazy. I got the smoke taken care of with a new injector but now whenever i'm driving and reach 2000 rpm the engine starts missing and is hard to accelerate, if I stay under 2k it's fine. I hooked up VCDS and pulled codes P1248 (Start of Injection Deviation) and P1246 (Needle lift sensor). Checked my injector contribution on group 013, all of the numbers were within the +/- 2 range and compression tested the cylinders which all came back over 400 psi. I already tried a new pressure relief valve in the IP which didn't help and when I bled the fuel lines to the injectors it ran great for a couple minutes and started acting up again. The pump itself is ticking like crazy. Is it time for a new Injection pump or do you guys have any other ideas?
