Old October 13th, 2017, 19:46   #1
coriscool
TDI(s): 2009 JSW TDI
Default What clutch do I need?
I have a 2009 sportwagon. I got the emissions recall fix done and I hated it. Huge loss of power and 4 mpg drop. So I got the kerma tune. Awesome returned the car to the one I love plus some.
Problem is now I'm starting to get some clutch slippage
Weird thing is it's only happening in 5th and 6th gear at full power and it's intermittent. I can still rail it off of stops on lower gears fine. It makes me think that the clutch is still good, it just can't handle the new torque output.
Either way I need a new clutch. Do I need to get a stage 2 clutch now? Which clutch do you suggest? Do I need to mess with the flywheel too? Vehicle is stock beside the tune. Thanks.
coriscool is offline   Reply With Quote
Old October 13th, 2017, 20:01   #2
turbobrick240
turbobrick240's Avatar
My factory clutch also slipped after getting tuned. I could slip it in most gears if I mashed the go pedal below ~2500 rpm. I just avoided doing that and drove it for a couple years that way. When I finally replaced the clutch it actually looked very good with not much wear. I think I just got a weakish Sachs pressure plate from the factory. Replaced it with Luk kit and flywheel and 20k miles later - no slippage so far. The Sachs sre is a good upgrade option if you want some extra margin.
Old October 14th, 2017, 10:10   #3
coriscool
So was that the oem level luk you put in?
Old October 14th, 2017, 10:45   #4
turbobrick240
Yup. I was in the middle of a 4000 mile road trip when I got nervous and had it replaced. Otherwise, I probably would have got a Sachs sre and done the work myself. But the Luk is holding my malone stage 3 tune just fine.
Old October 14th, 2017, 12:11   #5
Nevada_TDI
coriscool, I don't know the mileage on your clutch, but if it is slipping in 5th and 6th gear under load, she is not happy. I realize having a tune (from my personal experience) tends to make a person throttle happy, but--for a while at least--can you be less throttle happy? You also do not mention which level of tune you had installed, so that piece of info will be of help when it comes to clutch decision time. The short version when it comes to clutches is to buy one the next level stronger than you you need now, as later you want more power and not having to replace the clutch again saves money. I have a Stage 4 tune and my SB Stage 2 Daily Driver clutch hasn't even whimpered, and TBH, I didn't even notice any difference in pedal effort required when I upgraded my stock clutch.
I don't know if anyone near you has VCDS, but if you ever need your car scanned we can likely work something out.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, Stage 4 Custom TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is online now   Reply With Quote
06 BRM clutch pedal won't go all the way down after new sach clutch kit was installed Brealistic0 VW MKV-A5 Golf/Jettas 6 December 10th, 2015 04:02
post-clutch install, won't start.. ground wire? clutch sensor? AnnaTDI VW MKIV-A4 TDIs (VE and PD) 1 September 22nd, 2014 22:10
Replaced entire clutch system, now no start. Suspect clutch sensor. saucer VW MKIV-A4 TDIs (VE and PD) 10 October 6th, 2012 12:57
Replaced DMF clutch - now makes whooping noise when clutch partially depressed RickandJules VW MKIV-A4 TDIs (VE and PD) 12 July 30th, 2010 16:41
Clutch shudder a while back, now clutch slip. DBW: Upgraded DMF an option? InDiesel Exposure VW MKIV-A4 TDIs (VE and PD) 3 October 25th, 2002 20:54
Page generated in 0.12931 seconds with 11 queries
[Output: 69.96 Kb. compressed to 61.96 Kb. by saving 8.01 Kb. (11.44%)]
