Old January 20th, 2010, 11:22   #46
dvst8r
dvst8r's Avatar
TDI(s): '03 Wagon
So does a Bosch cp3 from a cummins/duramax fit easily? That would be my logical choice as they are cheap and plentiful, and support 600hp+ of fuel.
Cetane Racing
- Where a tdi turbo upgrade isn't big unless that "56" referrers to the inducer size.
Originally Posted by qmark
again, not a topic for this forum...take it to "people who give a ****" forum.....the only numbers hear we care about are hp/ftlbs...
dvst8r is offline   Reply With Quote
Old January 20th, 2010, 12:07   #47
TDIsyncro
TDIsyncro's Avatar
TDI(s): Audi/TDI x 2
Fuel Economy: 50-60mpg HWY, depending on speed and wind
It is not a bolt on, but the most logical solution and a fairly straightforward fit. Rotation direction will be correct as well. Issam is designing/making the bracket for it along with the dry sump system. I do not have a CBEA acc bracket, which I need to go along with the set-up.
Issam, what are the stainless studs you are talking about?
2001 Audi A4 - New Project - 2.0TDI CR 450HP All Turbo
http://forums.tdiclub.com/showthread.php?t=270527
2007 Canyon w/2011 TDI CJAA CR
http://forums.tdiclub.com/showthread.php?t=415533
TDIsyncro is offline   Reply With Quote
Old January 20th, 2010, 12:20   #48
TDIsyncro
TDIsyncro's Avatar
Originally Posted by shizzler
Awesome thread. Thank you for waiting until you had things mostly sorted out before starting it. Now start building, or at least show us some more TDI porn. :P
we are stumbling on somestuff here still, but things should break in the next 3 months and you will see a lot of progress after that. so sorry..a bit of waiting will stilll be needed.
Old January 20th, 2010, 12:22   #49
TDIsyncro
TDIsyncro's Avatar
Originally Posted by 87turboquattro
if someone would get the head out of my trunk,i'd get some more porn,i mean pics of it.
Chris, are you going to swing by there and give him a hand?
Old January 20th, 2010, 17:21   #50
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Oh I suppose...after all...I need a condensor for my forklift!
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old January 20th, 2010, 19:09   #51
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Originally Posted by TDIsyncro
Looks to me like there's room to increase the diameter of the intake valves by some amount still? I mean, not that I'm suggesting it, but we've seen valves enlarged to the point that it the seat hole was cut into the glow plug hole...
Old January 20th, 2010, 19:34   #52
87turboquattro
TDI(s): 97 passat
Fuel Economy: 42-46mpg city,52-62mpg hwy
but its the fire ring i'm worried about.valves are close to the cylinder wall.new pics will show this better.
87turboquattro is offline   Reply With Quote
Old January 21st, 2010, 06:37   #53
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Oh I see. I'll be interested to see those pics. Hope your recovery is going well.
Old January 21st, 2010, 07:09   #54
87turboquattro
TDI(s): 97 passat
thank you,its gonna be a long time,1 week down 7 to go.
i'm gonna get pics sent out today,no matter what
Old January 21st, 2010, 07:35   #55
mrchill
mrchill's Avatar
The fire ring is one area thats close. The deal killer is the injector mount boss area.
Old January 21st, 2010, 08:38   #56
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Forgive me that I'm dense; I can imagine that wall-thicknesses in the areas of interest in the head are quite small. The cylinder getting in the way is crystal clear. But I fail to see how the injector mount boss as you describe it -- and as I try to envision what you're referring to -- would be a limitation to accommodate slightly larger valves? Are larger valve seats pressed in, or the same ones used and just made thinner?
tdisyncro has access to an ultrasonic thickness gauge and was going to check the ports anyway. Maybe it would be good to also check this area of the head as well?
Old January 21st, 2010, 10:12   #57
TDIsyncro
TDIsyncro's Avatar
I am not sure how the injector pocket effect valve size, unless the port wall thickness is shared with the injector boss, and it can't be blended properly with a large dia valve hole. Is that what you mean Chris.
To answer your question Dave, the existing valve seat is cut larger.
Old January 21st, 2010, 10:20   #58
dvst8r
dvst8r's Avatar
TDI(s): '03 Wagon
I am curious as to your custom injectors.
I know of someone that has machined vw injector bodies to accept cummins nozzles, and has quite a wild set of custom injectors. It also sounds like (haven't actually talked to anyone) that nicktane can have a a pretty big set made.
Then there is also the route of going to someone like a DDP, or a JL Machine, or ect... and you could have new nozzles EDMed, then flowed and balanced via Extrude Hone.
Just kinda curious as to the direction you took, more then the specific size of the nozzles you had made.
Cetane Racing
Old January 21st, 2010, 10:50   #59
shortysclimbin
shortysclimbin's Avatar
On the piston side of things find yourself some pistons from an Audi TT CR with engine Code CBBBB The CR ratio is already 16.5:1 on those. This should allow you to cut your valve relief pockets bigger for your cam and be done with it.
Have fun with her, its always fun to build things from scratch.
shortysclimbin is offline   Reply With Quote
Old January 21st, 2010, 10:58   #60
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Wow, thanks for the tip, Kyle! I hope it drives home the point of the importance to limit PCP by reducing the CR if you want to build an insane setup and want the engine to survive.
I recall tdisyncro saying that replacing the pistons are not in the cards, but this gives something to think about, especially if oversize pistons are also available...
Page generated in 0.50143 seconds with 10 queries
[Output: 133.84 Kb. compressed to 111.98 Kb. by saving 21.86 Kb. (16.33%)]
