Old October 16th, 2017, 10:36   #16
ken.fresno-tdi
Fuel Economy: 30+ TDI Eurovan; 40+ on Jetta
Nice to see someone complete this. How did the electrical/wiring go? Any tricks that need to be figured out? How about mounting the go pedal?
ken.fresno-tdi is offline   Reply With Quote
Old Yesterday, 06:34   #17
archemitis
archemitis's Avatar
Originally Posted by jimbote View Post
right on, do you think an AC compressor will hang too far down ?
It looks like it would sit pretty low and might need some belly pan modification. I would say try it tough! I lifted mine, you just tighten the torsion bar nuts.
archemitis is offline   Reply With Quote
Old Yesterday, 06:39   #18
archemitis
archemitis's Avatar
The wiring was easy, because I just wired it as a stand alone unit. The gauges and dash and most everything is still stock. I need to put in a 4 cylinder cluster to get a working tach.
I used a pedal out of a 2000 golf, so I just welded a steel plate to the old gas pedal mount.
There is something with the old auto tranny. It had a neutral safety switch that wouldnt let the starter spin with the new 5 speed installed. I just traced the starter wire to before this safety switch and got power for the starter solenoid from there.
Im still excited over an oil pan that worked without modification, except for the drain plug has to be moved to the other side. It (the entire system) holds 4 quarts and the level sits just below the rotating part of the crank assembly.
Old Yesterday, 07:09   #19
ken.fresno-tdi
Did you replace or modify the in tank fuel pump? Or just let it remain and help give some more pressure to the ALH pump? I'd like to see a pic of the passenger side modified engine mount if you have one. That and the oil pan/pickup mod is what have me waiting to do a ALH conversion.
Re the wiring, if you don't run A/C that makes things a bit easier. Also no cruise control? That requires connecting with brake/clutch switches and stalk switch.
BTW, on my AHU conversion I mounted the intercooler in the front air dam under the bumper. Works great and mounts easily. No problem then pulling the radiator into service position to check oil and work on anything on the front of the engine. If anyone is interested my AHU conversion is documented here: http://kenssite.net/Eurovan/.
Turbo for ALH in a T4 Eurovan archemitis TDI Power Enhancements 22 November 16th, 2016 21:04
immo 2 eurovan (t4) SKC ewenmaclean OBD Scanners 6 May 22nd, 2015 05:10
AHU/ALH Eurovan T4, about transmission (5th gear swap, 02A swap) X@V TDI Conversions 46 March 24th, 2014 16:15
99 Eurovan T4 TDI conversion caddywompus TDI Conversions 28 March 22nd, 2013 15:51
Eurovan/ T4 2.4L Diesel Specs?? vwjunk_e General VW Discussion 3 August 19th, 2004 13:36
Page generated in 0.11920 seconds with 12 queries
[Output: 65.53 Kb. compressed to 58.95 Kb. by saving 6.58 Kb. (10.04%)]
