Old October 13th, 2017, 08:50   #91
diffas
diffas's Avatar
I'd rather put BW s252sx-e (it's also cheap - if that is the only spec needed for turbo) instead of Holset at any day, If you are aiming seriously for past 400hp. For smaller power something like gen1 gtx2967r .64a/r would be my choice. Comact size, big power and good spooling. And not that far from Holset price-range. Still just not quite sure why did i sold mine that had 63 comp. :P
OR
Customize some other turbo for your specs. I have quite a good single spooling turbo made parts our from k26, k27 and s200/efr.
Making twins to b5/b6/b7/c5 engine bay is quite a job but something might be fitted i'm sure. :P
diffas is online now   Reply With Quote
Old October 13th, 2017, 10:45   #92
Layerz
Originally Posted by Rub87 View Post
easy way out would be the 3.0 biturbo setup. its pretty cheap and compact and flows 400-420hp.
Pretty looking thing....http://www.ebay.co.uk/itm/Audi-A6-A7...YAAOSwdIFXxUT0
But Honestly I wasn't aware of that set up so well noted!
Edit:
Just seen Diffas reply.
My B6 will likely be a year in to making as I have a 924 that has a hell of a wiring/rewire job to tackle before I can use that to take the B6 of the road for a bit and in the meantime I'll be sorting everything else as I plan to have this car for a good few years..
I am tempted to get something else to play in between that leads to this - but something where mistakes can be afforded.
Layerz is offline   Reply With Quote
Old October 13th, 2017, 11:46   #93
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Originally Posted by Layerz View Post
It's a steal, someone buy it!!
Old October 13th, 2017, 22:37   #94
altz1
TDI(s): Allroad, A8
This is even better price:
https://m.ebay.co.uk/itm/Audi-SQ5-Q5....c100408.m2460
Not new tough, but will probably run long.
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
Audi Q7 4.2TDI 410hp, 900nm. - Sold
Allroad C6 under construction, 420hp goal.
BVN 4.2TDI project twin gtd2060vzk, 650hp goal.
altz1 is offline   Reply With Quote
Old October 19th, 2017, 21:41   #95
sector
I am starting to consider a GTB2260vk...But is the ECU change a must? MSA11 stock...Or is there any other ways?
sector is offline   Reply With Quote
Old October 21st, 2017, 02:20   #96
hatemi
Ecu change should be the first mod on these. Hje 8bit brick is limited in so many ways.
Lähetetty minun Moto G (4) laitteesta Tapatalkilla
www.tdituning.fi
hatemi is offline   Reply With Quote
Old January 19th, 2018, 00:25   #97
sector
What ECU would you guys recommend? EDC15vm+? Standalone ECU is problably a NO for the AEL? Also, does the OEM ECU have a speed limiter and how to disable it?
2.5 tdi 5cyl 140bhp AEL A6 Audi volkswarren Other VW Group TD(I)s 3 August 11th, 2009 14:28
Audi A6 2.5 TDI AEL - Need Vacuum pump info, brakes problem MrFree VW MKIV-A4 TDIs (VE and PD) 2 December 2nd, 2008 04:29
Audi A6 2.5 TDI AEL - Need Vacuum pump info, brakes problem MrFree TDI 101 0 December 2nd, 2008 01:08
Audi A6 AEL needle lift sensor ZAMP Other VW Group TD(I)s 15 October 17th, 2007 12:35
Audi A6 (AEL), error 542 needle lift sensor (G80) MrFree OBD Scanners 2 June 12th, 2006 06:56
Page generated in 0.15015 seconds with 13 queries
[Output: 85.00 Kb. compressed to 73.97 Kb. by saving 11.04 Kb. (12.98%)]
