50harleyrider
- Joined
- Jun 16, 2007
- Location
- charleston,wv
- TDI
- 2005 B5.5 TDI/geared BSM, BV43A turbo,stage 2 TDTUNING. 2005 5sp manual passat tdi stage 2 tdtuning,BSM delete. 2015 Passat TDI 6sp manual.
I just put a new Evolution skid plate oin my B5.5 and now have a bad vibration when I put it in reverse and load the suspension. It really vibrates bad. I watched the engine tilt forward when all this happens so I suspect the front motor mount is causing it. The two oil hydraulic side mounts were recently replaced but not this one. Should I go ahead and replace it since the car is at 200k and see if that fixes it? At this point it seems the logical thing to do as the plate was installed per the instructions and doesn't appear to be hitting the engine. It's really a nice plate and I hate to remove it especially with all the ice on the roads now.
