Keith J. Barton
- Joined
- Feb 8, 2002
- Location
- Cleveland, OH
- TDI
- 2004 Passat, Silverstone Gray 206k miles (gone but not forgotten: 2002 Jetta, Blue - 60k miles)
2004 Passat with 193,000 miles. Recently had timing belt and all that stuff done.
Also had to replace the serpentine belt tensioner because it was making a terrible racket and belt would squeal when turning at low speed (e.g., parking lot).
New tensioner was quiet for a few days, then the belt started squealing again but NOWHERE near as bad as it had been.
Took it back and for various reasons just tried replacing belt - tensioner seems tight, but how can you tell without doing some kind of test on the spring? How much does it need to be out of spec to be a problem? Anyway - it was quiet for a few days and started squealing again - but not nearly as bad as original problem?
The only thing I can think to do is replace the tensioner again, but the shop said they had another like mine that still squealed after a new tensioner. BTW - this is not a dealer, this is a respected VW dedicated mechanic who has had his shop in the same place since 1975....
Now What? Anyone else had a problem like this?
