GarretP, The trip you just did is not applicable to this situation. I think it is concensus that steady state driving like you just did is A-OK. It's the accelerating transients that are killing these turbos. According to mickey, a common factor is they blow when "pulling away from a stop." But thanks for the consideration.
Well, on to the good stuff, well really good stuff.
You missed a key piece to the situation... the smoke map. It caps fuelling for certain combinations of low fuel mass and low engine RPM. Hence the "saturation" condition I explained earlier.
When a stock TDI gets fat injectors, the ECU doesn't know that. The maps are calibrated for stock injectors. The additional fuel from the fat injectors can overdrive the turbine and result in overspeed. Same deal with the chipping feature that mods fuelling, obviously.
This is the really interesting stuff from SP:
Smoke is an accepted part of modding a TDI. It means "real man power" above and beyond the power at where the smoke map caps injected fuel mass. Doing anything to disable or diminish the smoke map puts the turbo at risk of overspeed due to additional fuelling beyond what the smoke map would allow.
Altitude just makes all the above much worse.
Hey SkyPup, that saturation that I was talking about, that's the smoke map capping off the max fuel mass delivery rate for the low RPM & air mass condition. That's why cars smoke when they get fat injectors. The ECU still thinks the injectors are stock and applies the stock maps. It don't work. Just like the stock maps won't work to provide implicit turbo overspeed protection when the ECU is chipped, or fat injectors are added, other things to add boost or fuel that the ECU does not "know" will result in turbo overspeed. All these types of mods lead to turbo overspeed since the turbo speed is not sensed, but implied by stock parameters.
You are absolutely galactically oblivious to the smoke map and its function. If the smoke map is side stepped when chipped, you should expect turbo overspeed. If fat injectors are added, turbo overspeed is to be expected due to the additional energy available from the additional fuelling to drive the turbine.
Ted_G, I don't think adjusting the max. boost nozzle position is a bad thing or should be avoided. Making the minimum nozzles bigger sort of "derates" the turbo, reducing turbo related load, speed and torque. This will help the turbo survive those transients.
<font size="2" face="Verdana, Helvetica, sans-serif">SkyPup, SkyPup, SkyPup,....Originally posted by SkyPup:
Thanks for clearing that misunderstanding up here aaron.
Everyone drives their cars differently across the entire gamit from super econo to super high performance.
You are right that Mickey's conditions are the most severe TDI torture test that I have ever heard of, and he doesn't even have 50 cetane fuel to assist him either.
Running full boost uphill under load at low rpms is the most damaging range to drive your TDI in due to the temperatures, pressures, and loads involved in. I would not maintain a 10-12 psi boost load uphill for more than 40-50 seconds without backing off to keep the temps down, or downshift to take the load off the turbo.
The turbo is a direct link to the load you are experiencing, and as you mentioned, a HSDI passenger car engine rarely sees a load like a 60,000 pound semi-truck does. Short burst of full load are entirely normal as you cannot floor the throttle for very long without exceeding the max speed limit, wherein the boost drops off as you take off the load.
I have had the cruise control on through the mountains 4,000-5,000 feet and going uphill I have had to take it off since it was putting too much load on the engine for uphill climb on long 10-13% grades, operating the throttle manually to keep the boost levels at medium levels 8-10 psi is much less stress on the turbocompressor.
Your intercooler air at 8-10 psi boost is just about right, there is really no need for intercooling to lower the intake air temps at that pressure. Once you get to 10-12 psi of boost the turbocompressor is working very hard and the intercooler is needed to cool down the boosted air. At 14 psi and above, our two TDIs both max out at 19 psi steady, the compressor is working extremely hard and the air temps are very high, putting a major strain on the intercooler to maintain lower intake air temps and decreasing the efficency of the compressor wheel dramatically as the temps rise from the continued high boost demand.
Very few OEM turbocharged vehicles of any make or manufacture have turbocompressors that are designed to put out more than 8-12 psi of boost, since this requires the use of an intercooler and a much more efficent wheel and creates much more load, temps, pressures, etc. Operation at anything over 10-12 psi for any length of time heat saturates the entire system and is NOT going to lead to long term reliability no matter who makes it or designed it. Excess heat destroys engines.
The altitude adjustments maps OEM on the TDI keep the max turbo pressure down below max operational limits for temperatures and the MAP-IAT sensor also decreases turbo boost too based on an intake air temperature correction factor.
Neither of these negative feeback sensors cuts down on the FUELING though, so you can still continue to make major heat due to the amount of fuel, even though the turbocompressor has been backed down by your internal barometric pressure maps and the temp correction of the IAT-MAP sensor.
It is up to you to manually decrease the fueling via the throttle, or risk toasting your turbo machinery. It will not overspeed and it will not surge under these conditions.
There is little to no chance of any overspeed occuring unless your air filter is dirty and occluded.
There is little to no chance of surge occuring unless you are full loading the turbo at the torque peak.
There is little to no chance of choke occuring unless you are giving it full throttle and no throttle and then full throttle again and the engine and turbospeed are mismatched from run-on.
Pay attention to those parameters and you should experience no problems during the lifetime of your TDI.
<font size="2" face="Verdana, Helvetica, sans-serif">The boost, IAT & MAP sensors don't sense turboshaft speed. Shaft speed control is implied but certainly not assured. Once the system is modded for more boost and or fuel, all bets are off and turbo overspeed is sure to happen. Especially at altitude.The altitude adjustments maps OEM on the TDI keep the max turbo pressure down below max operational limits for temperatures and the MAP-IAT sensor also decreases turbo boost too based on an intake air temperature correction factor.
<font size="2" face="Verdana, Helvetica, sans-serif">No, but the smoke map does. It can and will prevent overfuelling, if not tricked by chipping or fat injectors that will in turn overdrive the turbo and lead to overspeed. The main influencing factors in fuel regulation are the MAF and smoke map, after the pedal position. Look at the smoke map.... low air mass and low RPM results in fuel mass being capped off. You missed that SkyPup. Wait, maybe the chippers don't use the smoke map.... If they did, the smoke map would override the increased fuelling and what good would that do? Certainly wouldn't increase torque over stock.Neither of these negative feeback sensors cuts down on the FUELING though, so you can still continue to make major heat due to the amount of fuel, even though the turbocompressor has been backed down by your internal barometric pressure maps and the temp correction of the IAT-MAP sensor.
<font size="2" face="Verdana, Helvetica, sans-serif">This wouldn't have to be done manually if the ECU or other system components weren't modified. The smoke map will cap the fuel mass dependent on the air mass and engine RPM, if the system has not been disturbed by mods such as fat injectors and chips that will lead to overdriving the turbine.It is up to you to manually decrease the fueling via the throttle, or risk toasting your turbo machinery. It will not overspeed and it will not surge under these conditions.
<font size="2" face="Verdana, Helvetica, sans-serif">A stock A3 paper filter has 22 mbars of pressure drop at 3500 RPM. Absolute diddly squat. No problem. One squished mosquito on the windshield causes 387 mbars of intake pressure drop. No problem. High boost (=high PR) at low engine RPM where the flow through the compressor is low can easily cause overspeed or surge. Hey, if the system is not corrupted, the smoke map can also help prevent turbo overspeed..... Hmmm..... Did ya ever think of that???There is little to no chance of any overspeed occuring unless your air filter is dirty and occluded.
<font size="2" face="Verdana, Helvetica, sans-serif">This can happen anytime in normal vehicle operation. Duh!!!There is little to no chance of surge occuring unless you are full loading the turbo at the torque peak.
