Old May 16th, 2010, 08:21   #346
rocketeer928
rocketeer928's Avatar
Default Koni Sport Springs
Two years ago I installed Koni FSD struts and shocks on my Jetta TDI. At the time, I decided not to spend the money on new springs because the FSDs were advertised as working well with the OEM springs, and they did.
Late last year, the Koni Sport Springs went on sale, so I bought them, and yesterday, I finally got around to installing them. As advertised, the new springs lowered my car about 1-inch all around. Of course, my wife doesn't understand why I NEED to lower my car at all.
I used new strut mounts and all the essential bolts and nuts holding everything together. An air impact gun is a must for removing and installing struts and shocks, as well as spring compressors.
When I removed the front struts to install the new springs, I scraped off the chipping paint and repainted them with Gold Rust-Oleum spray paint. Amazingly, it was the same shade of gold. It bothers me that after spending so much money on the FSDs that the paint started to chip right away, which caused them to start to rust. I've heard others complain about the same thing. Realistically, the chipping and rusting will likely continue. Regardless, the FSDs work great, and hopefully the new springs will make the driving feel even better.
Tomorrow after work I'll go get the wheels re-aligned.
2003 Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray
yo
1970 VW Type 3 Squareback - Cobalt Blue (Birdie)
rocketeer928 is offline   Reply With Quote
Old May 16th, 2010, 12:14   #347
squire89
squire89's Avatar
TDI(s): 2002 jetta
Fuel Economy: low 40s
the set up you have is very very nice. I used it for like a year and a half before i upgraded to some fk coilovers. it will handle a lot nicer in the corners.
for another well needed mod on this platform look for a used 28mm swaybar. brand doesn't matter, but it will reduce body roll a fair amount. you won't need to worry about your front one for the most part, but it wouldn't hurt to upgrade to your front endlinks(not too expensive). i don't know how much that it helps as i did a lot all at one time.
2002 jetta
check the thread for mods along the way
squire89 is offline   Reply With Quote
Old May 16th, 2010, 16:23   #348
rocketeer928
Thanks; I'm sure I'll like it too.
I already have a rear sway (stabilizer) bar (Post Nr. 76) and an Upper Front Stressbar (Post Nr. 121). I don't get much body roll with these two bars plus the DG Panzer Plate installed.
yo
Old May 16th, 2010, 21:21   #349
tothemax
tothemax's Avatar
This job is such a PITA.... What a ball buster... I have to say R&R the front shocks is for me one of the most back and knuckle busting jobs on my car. Glad it was you Chris and not me doing this. You will love the lower springs and the way the car will look and feel. Good Job! Post some photos of how she looks with the lowered stance and the body work.
tothemax is offline   Reply With Quote
Old May 17th, 2010, 00:15   #350
squire89
squire89's Avatar
TDI(s): 2002 jetta
i'm sure the car will look very nice. i am looking forward to seeing some updated pics of this fine modded machine.
2002 jetta
Old May 17th, 2010, 00:22   #351
squire89
squire89's Avatar
TDI(s): 2002 jetta
what do you currently run for rims in summer?
2002 jetta
Old May 17th, 2010, 05:26   #352
rocketeer928
Squire89, you can see the answer at Post Nr. 267, including a picture.
Now that the front third of my car looks so nice with the new paint job, I want to replace the scratched up bottom air deflector (spoiler). After that, I'll take some pictures and post them. Maybe I can convince my wife to take a picture of me with my project car.
While working on the car this past Saturday, my wife comes out to the garage and asks, "Why can't getting into the car, turning the key, and just going be good enough?" Women! Most just don't understand our desire to make our rides better.
Yes Pierre, the whole job is a pain. Now you know why it took half a year for me to finally install the springs. However, since I installed the struts and shocks two years ago, I knew what I was up against. That Metalnerd spreader bit doesn't work as well as I would like, and I totally ruined a nickel to get some more opening space for the struts. Even installing the rear springs was a pain (hint: be sure to disconnect both shocks before removing and installing springs). It pretty much took me all day to do this job, and I'm glad it's done. I was rather tired on Sunday morning. I still think changing out a clutch and flywheel is harder, and I did that twice!
I have to say that I'm not sure what "R&R" means. Maybe I'm getting old and this is some sort of texting jargon; though I'm not really that old (i.e., not too many gray hairs). To me, "R&R" means rest and relaxation, which this modification certainly is not.
Two more modifications coming soon, and then an upgrade to RC5 in June.
yo
Old May 17th, 2010, 07:20   #353
shizzler
TDI(s): 05 BEW Wagon
Fuel Economy: mid 40s
Haha. Nice work, also waiting for new stance pics!
R & R is "remove and replace"
'05 Jetta Wagon: For Sale
shizzler is offline   Reply With Quote
Old May 17th, 2010, 10:31   #354
squire89
squire89's Avatar
TDI(s): 2002 jetta
if you don't have it already look into the 4 motion front valence or spoiler as you called it
2002 jetta
Old May 17th, 2010, 16:17   #355
rocketeer928
I decided against the Bora 4-motion front valence. I don't really like the look of it, and I was able to pick up the OEM front valence and a water deflector (mine broke a few months ago) from my local dealer at wholesale.
yo
Old May 18th, 2010, 19:59   #356
tothemax
tothemax's Avatar
Yes, taking out and putting the tranny back in is another bear. I have to swap out trannies between my Jetta and Golf and I dread doing it. I think I will pay my neighbor kid to do it for me. The 3.16 R&P may be great for a daily driver but it totally sucks for an autoX car.. It's gotta go .. .the second gear is way too tall and too slow. Going back to stock tranny in the Golf and I will use the 3.16 R&P in my daily driver Jetta.
You will love RC5 ....
Where are the photos of the lowered stance?
Old May 19th, 2010, 04:38   #357
rocketeer928
Ugh! The demanding pressure is killing me.
It's been raining lately. Supposed to be nice the next few days, so perhaps I'll be able to wash the Jetta and take some nice pictures. I would like to install the new front valence first, which I might be able to do tonight.
yo
Old May 19th, 2010, 05:22   #358
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
LOL, careful there, people get offended when you tell it like it is .
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old May 20th, 2010, 08:05   #359
rocketeer928
Default Wheel Alignment after Koni Sport Spring Installation
Here are the results of my wheel alignment after installing the Koni Sport Springs. The front was off a bit, but all is good now. Most important to me, my steering wheel is still straight (pet peeve).
yo
Old May 26th, 2010, 07:04   #360
MikeS_18
MikeS_18's Avatar
A good response: "Same reason one pair of black shoes just isn't enough."
'03 Wagon, 5spd,17/22 turbo, RC3+, PP520s, Stage 1 clutch, Old Man Intake, Lift Pump, TT Short Shifter, EGR Cooler Deleted, 800 Mile/tank club
2013 Passat SE and a '64 Ford Econoline Travel Wagon, 200ci straight six, 3 spd, 17mpgs "If it's got a hood, it ain't no good!"
6 Garages?! It's still not enough!
MikeS_18 is offline   Reply With Quote
Page generated in 0.19809 seconds with 10 queries
[Output: 144.81 Kb. compressed to 121.32 Kb. by saving 23.49 Kb. (16.22%)]
