MorganHatfieldx
I'm new here so bear with me. I have a 2005 BEW, I can't get the thing to start. It had a cam position code for the sensor and I verified it wasn't reading when cranking. Replaced the sensor and now no codes no start. Found the lift pump not coming on. I used a aftermarket pump with 12psi right into the fuel rail I ran it out of a bucket and also had the fuel return going back to the bucket. No fuel return even while cranking. Also I bought the car like this. They said it was running and driving until it was shut off and then would not restart. If it sits it seems to run for a second then die. Everything after is just cranking and occasionally tries to fire.
That's all the further I got to mess with it today. I was thinking the tandem pump has gone out but I'm not sure. Anyone have some insight? I could always figure out my other tdi(1997 1z) but this one is messing with me.
