Where is the headlight relay MkIV
Tim_Mackinlay
London, Ontario, Canada
2005 Blue Golf Tdi 2004 Golf Tdi
The wife's 2004 Golf headlights (Low beam) quit.
The is no voltage at the light socket.
Does anyone know where the relay is located?
I see that 173 is the DRL relay, But swapping it did not make a differance.
Tim
JASONP
Guelph
2015 Golf TDI Comfortline 6spd
Tim, did you check the fuses?
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).__________________
JASONP
Guelph
I knew you would, have but had to ask.
Did some searching and found also maybe the Turn/Flash/Cruise Combo switch, but no luck on the location of the relay
JASONP
Guelph
Tim_Mackinlay said:
False alarm, It was the bulbs. Sheesh!!! Both at once!
First time for everything I guess.
Tim
I did see a thread on that as well, weird :confused:
Oh well
johnnloki
bowmanville ON
04 Golf TDI
Nothing chews up headlights faster than a mk4 golf.
I've had a pair of bulbs go in a couple of months... out of the package to landfill far too fast for my liking.
They tend to most often go pop when they're full off, and you turn on the headlights without dropping the parking brake first. Fully cold to full voltage is not so good with h7 bulbs.
Jetta_Pilot
West Hill, Ont.
That's one of the nice things about having a Euro switch. I am using an aftermarket HID kit and to extend the life of the bulbs, I only use my parking lights in the daytime. It has become an instinctive habit for me to turn the switch to the 12 o'clock position before starting the engine. Also when I shut the engine off I return the switch to 12 o'clock if I have been driving at night and then when the key is in the off position turn the switch to the off position.
The reason I follow this procedure, I have noticed the lights go off and momentarily come on again before shutting down altogether. Not too good for the bulbs.
compu_85
Gadget Guy
La Conner, WA
... None :S
For the record there is no relay for the headlights on any VW up to the mk5, all the power goes through the headlight switch.
-Jason
jnsrogers
Oklahoma
2005 gls TDI (BEW)
173 relay on 2005 Jetta TDI MK IV
So I removed the 173 relay and it only has to do with DRLs? Nothing to do with my low beam headlights not working?
