futbalfantic
I've been trying to fix a hard start situation with my Golf for some time.
It started with a previous starter replacement. I replaced the org. starter but in doing so one of the mounting bolts started to come loose with did not allow the bendix to engage the fly. Did not realize this before I ordered a new one. The teeth on the original starter looked out but the leading edge had some grinding. Installed the new starter.
This brought on a new problem. Seemingly slow cranking speed. (not sure how to test this but what it sounded). Turned the key to starting position, engine turned out for 10 seconds with no start. Multiple attempts will start the car. Tested the battery and found it to be low voltage on starting. Tested with a carbon pile and found it weak.
Replaced the battery and with this instead of 20 attempts it brought it down to 10ish. Problem persisted with slow and inconsistent cranking speed.
https://forums.tdiclub.com/showthread.php?t=344364
I read through this link and tested this best of my ability with the equipment I have. (no back probe). I disconnected the harness from both ends and found no continuity between any of the three terminals. Tested the crank sensor and it was outside of specs. Replaced the sensor.
Now I'm down to 2-3 attempts but it remains with slow/inconsistent speed.
I'm out of ideas
I'm out of ideas
