Hello all, new to the thread...
Recently bought a 03 Golf 5sp with 191k miles. When I checked it out, the clutch seemed great (original). And it still works fine! However, when I was driving home with the car (went 5hr north to get it), I noticed some noises that I hadn't noticed in the test drive.
There's some type of irregular chatter or rattling whenever the car is in neutral (whether I'm parked or about to turn off the car), and I realized today that the sound lessened when I would press the clutch in. This is leading me to conclude what it might be, the flywheel. Really wish I would have noticed it when I was test driving it around, blame my untrained ear. TB was replaced at 150k, so I think that can rule out any idlers or something coming from that area gone amok.
The chatter isn't horrible sounding, and you'd probably not notice it if you weren't listening for noises. Who knows if the previous owner even noticed it tbh. However, I'm reading that if it is the flywheel, then you want to have this switched out ASAP.
What I wanted to ask posting this, is how difficult is replacing this flywheel going to be? You have any good guides to help out with this process? Do you recommend to replace or check anything else while I have the transmission out? I'm probably going to go with the LuK kit that comes with clutch and flywheel attached, people seem pretty happy with it. Yes, I know that I can switch to a SMF, but want to keep it as OEM ride as possible, and I'm going to make as few mods as possible to this car (MAYBE Malone stage 1). Thanks!
