Here's the scan. Last year, actually.
Saturday,11,November,2017,14:55:41:47983
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWSR61J74W176393 License Plate:
Chassis Type: 1J (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: WVWSR61J74W176393 Mileage: 246020km-152869miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 906 016 H HW: 028 101 114 6
Component: R4 1,9L EDC G000SG 6327
Revision: 12345678 Serial number: VWZ7Z0D9260673
Coding: 0150031
Shop #: WSC 00000 781 00017
VCID: 1933A0AAD322DD8E6D-5140
4 Faults Found:
18996 - Turbocharger Boost Control Position Sensor Circuit
P2564 - 000 - Signal too Low
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -1.3 %
Absolute Pres.: 183.6 mbar
Absolute Pres.: 999.6 mbar
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00101100
Temperature: 21.6∞C
Bin. Bits: 00110000
16512 - Coolant Thermostat Valve (N214)
P0128 - 000 - Temperature below Control Range
Freeze Frame:
RPM: 1386 /min
Torque: 132.0 Nm
Speed: 62.0 km/h
Temperature: 64.8∞C
Fuel Consump.: 4.00 l/h
Temperature: 32.4∞C
Temperature: 32.4∞C
Absolute Pres.: 1356.6 mbar
16725 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 882 /min
Torque: 72.0 Nm
Speed: 17.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00001111
Idle Stabilization: 0.0∞KW
(no units): 48.0
Readiness: 1 3 0 0 1
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 01266 785 00200
VCID: 336F7202518E07DE47-5140
No fault code found.
Part No: 1C0 909 605 F
Component: 17 AIRBAG VW61 0108 0003
Coding: 12599
Shop #: WSC 01266
VCID: 27579652C5567B7EEB-5104
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 906 Q
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 15232
Shop #: WSC 00222
VCID: 3B7F5A2229DECF9E9F-5104
WVWSR61J74W176393 VWZ7Z0D9260673
2 Faults Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01330 - Central Control Module for Central Convenience (J393)
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01266
VCID: 70E5BD0E30187CC67A-5104
2 Faults Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8A Komfortger·t HLO 0003
Coding: 00258
Shop #: WSC 01266
VCID: 3777461215F6EBFE7B-4B04
Subsystem 1 - Part No: 1C1959801A
Component: 8A Tırsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802A
Component: 8A Tırsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811A
Component: 8A Tırsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812A
Component: 8A Tırsteuer.HR KLO 0202
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 G
Component: Radio PM6 0016
Coding: 00031
Shop #: WSC 01266
VCID: 244D815EB4609066CE-5122
End-------------------------(Elapsed Time: 05:15)--------------------------
