atrussell129
04 jetta tdi, 182,000 miles, new timing belt kit installed by deal 6 months ago but had starting issues before that. New in tank lift pump, new Tandem pump, and all new rubber hoses in engine bay. new Crank sensor, and grounded the wire for the crank sensor that always gets a short in it. New coolant temp sensor. New fuel filter without thermostatic T to eliminate any chance of air getting in line that way. I live in Florida so I never worry about cold starts. this also has a brand new battery.
Car takes a very long time and some time several cycles of cranking to finally start up first thing in the morning, I do not have this issue unless the car sits for about 5 or more hours. I am all out of ideas with what could be the issue.
Any help would be greatly appreciated.
