0die
Having some "low speed" or "low rpm" brake issues...
normal driving speeds/rpms the brakes are solid. It seems when I take it out of gear when I'm coming up to a stop it appears to brake fine the first pedal push or two...then as I get slower and real close to the stopping point I find that the brake pedal is suddenly harder to push with loses braking ability. I need to push extra hard to safely stop.
As soon as I drive off (rpms up) the brakes work just fine again as long as I'm driving down the road and the rpms are above idle range...until the next time I come to a stopping situation at idle.
It's kinda like the vacuum pump is putting out enough vacuum somewhere above idle but not at idle...
Is there a vacuum resivoir (no I can't spell it) involved in the braking system? I know there is one for the door lock system but not sure if it's connected to the driveline system.
Is the B4 pump rebuildable? My old Rabbit pumps were.
