prometheum
Just like the title says; it started this spring, whenever I turn on the AC it will take 10-15 minutes to actually kick on, but when it finally turns on it's really cold and works great. What could it be?
Likely relay 384 and it is repairable.Lots on the forum here about the control relay for ac cracked solder joint
yep found it; and the cracked solder joint. Hit it with the iron and now it works great!Likely relay 384 and it is repairable.
