hyoomen
- Joined
- Jan 9, 2006
- Location
- Dallas, TX
- TDI
- 2002 Golf GLS 5-speed; indigo blue; ~180k miles; stock (*WRECKED*). 2002 Jetta 4spd Auto (01M), indigo blue, ~246k mi, stock
In the middle of a marathon series of (mostly) maintenance tasks on my 2002 VW Jetta TDI w/ ~250k miles (head reconditioned by Frank06, block cleaned and prepped for head gasket, new high mileage timing belt kit, etc.) and while diving in to cleaning the turbo while it's off the car, I came across a rather disheartening sight.
Note the significant wear on the actuator ring (bottom of pic)
When I pulled the ring, I could actually see some of the metal that had been worn away still hanging on at the edge
The internal ring actuator lever has apparently had the upper 80-90% of its ring actuating profile worn off by ~10%
My assumption is that the ring and lever had enough play in their vertical alignment to each other that the buildup of carbon caused the lever to not maintain a complete contact surface w/ the ring. Thus, as the ring became less able to rotate smoothly, the lever was worn unevenly. Its possible the bottom sliver of unworn lever may even have been getting trapped by the outer surface of the ring when the two connected.
Per this thread from 2003 (Anatomy of a Failure: VNT actuator wear (images)), I suppose it is possible I can have the lever and ring both welded to have the missing material restored. No clue how to go about finding a local 'die repair shop' to do the work.
Just thought somebody might be interested, especially if you've been chasing your tail on an unresolvable overboost issue.
