Cruise control stalk and wiring
AKAvant
Europe
2004 Audi A4 Avant 1.9TDI Quattro, 2002 VW California, 1998 Jetta TDI (Sold 6/16), 1997 B4 Passat TDI, 1993 Eurovan Weekender 1Z m-TDI conversion (Sold 5/12), 1992 AHU powered B3 Syncro Wagon
Will the cruise control stalk and wiring harness from a gas MkIII or B4 work for an AHU? I know the gas versions use vacuum assist while the ECU controls the TDI's. Thanks!
AKAvant
Europe
I can't find my shop manual at the moment (that's what I get for cleaning the garage) to look at the wiring diagram and I don't have a TDI cruise/wiper/blinker harness to compare to either. Anyone have any ideas? Thanks
AKAvant
Europe
My desire is to have my cruise control work when I swap an AHU into a B3. I have a B3 pedal cluster that has been made to accept the potentiometer but I was wondering if its associated brake and clutch switches would allow for the TDI cruise control to work, or is a TDI specific pedal cluster needed?
My donor car was a running but not moving B3 Passat with an AHU swapped in, but it was done somewhat crudely and I'm still trying to figure out what wiring was placed where and I had no way to check if the cruise worked.
Basically my questions is do I need a TDI specific: pedal cluster with its brake and clutch switches, cruise control switch and harness from the switch to the fuse box?
Thanks guys!
kooyajerms
grocery getter
Pomona, Southern California
97 B4V (mine), 11 x5 35d (hers) 04 V10 (that one you want), 2014 Q7 (mom's) 74 Shasta 1400
I can't give you an affirmative, but I am running a mfa stalk/cruise stalk from a vr6 I believe (to work with my mfa)...
jjcsnlynn
Felton, DE
02 & 03 Jetta TDI,99 Beetle TDI, 04 Chevy Duramax 2500HD 4x4
I believe it will. I've been working on a 97 VR6 cruise and I checked out the stalk and it appears to be the same as my B4 (and the replacement 98 jetta stalk I replaced it with).
AKAvant
Europe
Awesome, thanks guys! This is great to know, saves me alot of time having to compare wiring diagrams and wiring harnesses etc..!
