1998993C2S
Hey Gent's - Anyone using a newer ... Mobil1 FS X2 5W-50 weight oil in their Pumpe Duse 1.9l BRM diesel? The FS X2 formulary does not meet VW spec 505.01 however the oil does meet Porsche A40.
For oil shear attributes the Porsche spec's C30 & A40 are light years beyond VW spec., 505.01 IIRC. See Mobil spec's below..
The western Colorado summer temperatures are *90F + and above seasonally, May thru September.
Historically I've been using Valvoline (VV-966) SynPower MST 5W-40 w/ VW 505.01.
Adopting the 7K to 7.5K mile OCI (Original cam/lifters R&R @ 156K mi)
Mobil 1™ FS X2 5W-50
Advanced Full Synthetic Motor Oil
Applications
The balanced technology of Mobil 1 FS X2 5W-50 helps to make it suitable for many types of vehicles and operating conditions, from mild to severe.
Specifications and Approvals
Mobil 1 FS X2 5W-50 meets or exceeds the requirements of: API SN, SM, SL, SJ X
According to ExxonMobil, Mobil 1 FS X2 5W-50 is of the following quality level: API CF X ACEA A3/B3, A3/B4 X
Mobil 1 FS X2 5W-50 has the following builder approvals: PORSCHE A40 X MB-Approval 229.3 X MB-Approval 229.1 X
Typical Properties
Mobil 1 FS X2 5W-50 Value Viscosity, cSt ASTM D445 @ 40ºC 104.3 @ 100ºC 17.1 Viscosity Index 179 Sulfated Ash, wt% (ASTM D874) 1.34 Phosphorous, wt% (ASTM D4951) 0.1 Flash Point, ºC (ASTM D92) 232 Pour Point, ºC -42 Density @15ºC g/ml, (ASTM D4052) 0.8499 Total Base Number (ASTM D2896) 12.6 MRV at -35ºC, cP (ASTM D4684) 24800 HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 4.4Health and Safety
- Prevents deposits and sludge build-up to enable long and clean engine life
- Anti-oxidants to help improve oil life
- High performance basestocks combined with a precisely balanced component system for excellent all-round wear protection
- Wide viscosity grade to help provide a flexible combination of high and low temperature protection
- Performs and protects at low temperatures
Applications
- Many gasoline and diesel (without Diesel Particulate Filter) engine technologies
- High performance engines
- Most operating conditions, from mild to extreme
Typical Properties
