Old April 15th, 2019, 06:56   #1
ranger pete
TDI(s): 2011 JSW 6MT
Default Partially heated seats.
I am the new owner of an '11 JSW. It has heated pleather seats.
I love heated seats, or more accurately, my stiff lower back loves them. My nether regions.....not so much. Things down there get sweaty enough as it is without help from a heated seat.
So, my question is, how difficult would it be to defeat the seat heat portion while retaining the back heat?
I would like to retain seat heat for chilly mornings, if possible, but if that gets to complicated, I will settle for back only.
Should be rather simple, assuming each heating insert is 12v and they are in parallel. If they are 2 6v pads in series though, it might be a problem.
ranger pete is offline   Reply With Quote
Old April 15th, 2019, 07:54   #2
sandmansans
TDI(s): 2014 Jetta
Fuel Economy: Best tank:54.7. Drove From Chattanooga Tennesse to Poconos PA
A quick look in the manuals, shows that there are in fact 2 sperate heating elements. So I guess you could open it up and repin the harness to only go to the back portion, but that may require you to unstich the seat cushion.
You might be able to do this via vcds, you would be better suited in searching and asking in the Ross tech forum. That in my opinion would be the easiest and best way to go about it, if it's possible that way you retain the function for the future and you don't have to take apart the seat
Sent from my Moto G (5) Plus using Tapatalk
sandmansans is offline   Reply With Quote
Polo 9n3 heated and partially electric seats upgrade Welington K. Upgrades (non TDI Engine related) 6 October 13th, 2017 08:52
Is it hard to add heated seats to non-heated Jetta? GIDDY_UP_GO VW MKIV-A4 TDIs (VE and PD) 1 February 6th, 2017 18:57
FS: Black Velour heated seats from Jetta Sedan (back seats included) PWM RockRockRock Private TDI Items for Sale/Wanted 1 October 11th, 2014 15:09
FS: Passat black, leather, manual, heated seats with Jetta sliders and Mk4 rear seats Area351 Private TDI Items for Sale/Wanted 14 February 15th, 2014 06:40
MK5 seats into an MK4.....$40$ to whoever can figure out the heated seats mannytranny VW MKIV-A4 TDIs (VE and PD) 11 December 15th, 2008 12:35
Page generated in 0.12904 seconds with 12 queries
[Output: 53.03 Kb. compressed to 49.15 Kb. by saving 3.89 Kb. (7.33%)]
