milkyjoe01
Can anyone shed some light as to the correct torque setting & procedure for tightening the front hub to axle BOLT (not a nut) on a 2004 Audi A3 2.0 TDi. It is a genuine Audi bolt, the 12 point, triple square bolt with no splines underneath the bolt flange, it's just smooth. I've read about so many different methods & torque settings it makes my head spin!! Some of the advice given was tighten to 200 Nm & immediately after tighten it an extra 90 deg. another opinion was tighten to 70 Nm & an extra 60 deg. & also slackening off the bolt then tightening a further 180 deg & even 1 that says torque to 200 Nm slacken by 90 deg. you then have to rotate the wheel 1 complete turn & then torque to 90Nm & then a further 90 deg.!!!! HELP!!!! Some of these answers came from the Bentley manual & some from an Audi tech!!! Can you give me your answers in newton metres please. Thanks.
