I'm almost done with my '00 Golf's new timing belt job but have run into an odd problem. Got the main and cam seals replaced, new rollers et al and belt in, and have manually moved the belt through 3-4 cycles. The next step (per the club's pdf) is to bump the engine for a few secs to center the belt and see if it is riding OK on all the pulleys. My problem (if you can call it that) is that I can't bump the engine more than one or two compression cycles without it catching. So we were hitting the starter for tiny fractions of a second each time. Not really moving the belt all that much before it starts.
So my question is how to proceed: Just skip the belt alignment now and check it later when the engine is more together and can run for longer? Just turn it by hand a few dozen more times?
FWIW, right now the new tbelt is centered just fine on the cam pulley, but running a bit (1-2mm) more towards the engine on the IP pully. It's not hitting the inner cover but is closer to it than the old belt was. The old belt, btw, was in fine shape with no indications of side wear, so I would hope the new belt would not change that, but so far the new belt is running more to the engine on that IP pulley.
Suggestions?
Suggestions?
