demhaizar
- Joined
- May 31, 2005
- Location
- BFL, CA & SW, MI
- TDI
- Jetta TDI 2006, 328d X-Drive, 2015 Passat TDI SEL DSG
Hello,
My rear windows stopped working, along with the alarm not chirping when set(doors do lock), the parking lights don't flash when setting the alarm, the rear door lock switches and window switches are not working.
I have checked every fuse in the panel by the dash drivers side as well as the fuses in the engine fuse box all have continuity and physically look good.
Is there a relay/s to check? location?
...have not checked the drivers door harness as yet.
here is a VCDS scan:
Sunday,12,July,2020,19:30:12:64076
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
Workshop Code: 818 10570 062420
VIN: 3VWDT81K36XXXXXXX License Plate:
Mileage: 568410km-353193mi Repair Order:
Chassis Type: 1K-VW35 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 36 37 42 44 46 47 52 55 56 62
6C 72 77 7D
VIN: 3VWDT81K36XXXXXXX Mileage: 568410km-353193miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
77-Telephone -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E3111421
Coding: 0050078
Shop #: WSC 66565 257 00032
VCID: 64CC1066A7A1F3A68F-8030
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000511031023
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 51A2C9B2C813760ED4-8004
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
Shop #: WSC 62420 457 45789
VCID: 71E269326853560EF4-8024
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BN HW: 1K0 907 044 BN
Component: ClimatronicPQ35 110 1010
Revision: 00110021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 74EC6026174163261F-8020
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000006038016
Coding: E7008A0140041800470000000F000000801950036400000C000000000000
Shop #: WSC 62420 123 12345
VCID: 336EA33A52CF241EC6-8066
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 62420
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 260707 046 0204
Coding: 00471077
Shop #: WSC 62420
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 4
Reset counter: 22
Mileage: 568375 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.95 V
ON
ON
OFF
OFF
OFF
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 22
Mileage: 568375 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.95 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 38 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD038SRJ
Coding: 0013112
VCID: 3972911270A3DE4E0C-806C
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME0C4015283
Subsystem 3 - Serial number: 6342MSME0C410B37A
Subsystem 4 - Serial number: 6351HSME09005E5BB
Subsystem 5 - Serial number: 6361HSME0902601E0
Subsystem 6 - Serial number: 63727SME08440C5E7
Subsystem 7 - Serial number: 63827SME0851606D0
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0001711
Shop #: WSC 65950 121 62420
VCID: 7AF04E1E3525155645-802E
Subsystem 1 - Part No: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5N0 920 883 C HW: 5N0 920 883 C
Component: KOMBI H04 0611
Coding: 271B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 346CA0269FC12326DF-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4540K1042383F7
Coding: ED81FF16504602001002
Shop #: WSC 10570 818 62420
VCID: 69D201524083AECEBC-803C
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0611
Serial number:
Coding: 000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6AD07E5E8D85A5D6B5-803E
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
Shop #: WSC 00065 000 00020
VCID: 2C5CB8468FF17BE687-8078
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 J HW: 3C0 035 684 G
Component: RNS-MID H01 4366
Revision: AB001001 Serial number: VWZ6Z7M5130029
Coding: 08050042010000A00006
VCID: 2A50BE5E450565D675-807E
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V12 8534
1 Fault Found:
01550 - Signal for Reverse Gear
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Date: 2020.07.12
Time: 11:40:04
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 36689A2E41BD3136E1-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 3260A63EADD52D16CD-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 1B900E880106083F2D02058FB0088F0480A140
VCID: 020036FE5DF55D961D-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Date: 2020.07.12
Time: 11:40:01
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Date: 2020.07.12
Time: 11:40:01
Address 47: Sound System Labels: 3C0-035-456.clb
Part No SW: 3C0 035 456 C HW: 3C0 035 456 C
Component: DSP 10 Kanal 0012
Revision: 00009000 Serial number: 00000000004585
VCID: 20445C76F339AF862B-8074
1 Fault Found:
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 6
Reset counter: 22
Mileage: 568375 km
Time Indication: 0
Date: 2020.07.12
Time: 11:40:02
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 3776972A46B7C83EFA-8062
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0001
Coding: 0000003
Shop #: WSC 01316 785 00200
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Date: 2020.07.12
Time: 11:40:04
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663378856
Coding: 0A10040000010110
Shop #: WSC 00001 001 00011
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A708E1EBDA5D55605-806E
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5AB542B4EB72EE90-8078
End-------------------------(Elapsed Time: 02:44)--------------------------
Thanks for stopping by...
www.Ross-Tech.com
6C 72 77 7D
Coding: 0050078
Coding: 0000020
Revision: 00H13001
Coding: 0021122
Coding: 00063445
Shop #: WSC 62420
Coding: 00471077
Shop #: WSC 62420
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 22
Mileage: 568375 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.95 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 22
Mileage: 568375 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.95 V
ON
ON
OFF
OFF
OFF
Coding: 0013112
Coding: 0001711
Coding: 00000130
Shop #: WSC 00000
Coding: 271B00
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Serial number:
Coding: 000000
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Date: 2020.07.12
Time: 11:40:04
Coding: 0001269
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Date: 2020.07.12
Time: 11:40:01
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Date: 2020.07.12
Time: 11:40:01
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 22
Mileage: 568375 km
Time Indication: 0
Date: 2020.07.12
Time: 11:40:02
Coding: 0001269
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 21
Mileage: 568375 km
Time Indication: 0
Date: 2020.07.12
Time: 11:40:04
Cannot be reached
Cannot be reached
