Exaust leak at flex joint
Diesel2005Golf
Ottawa, ON, Canada
2003 Golf
There is a flex joint that in an integral part of the down pipe as it exits the engine compartment. This has failed more than a few times during the life of the car. Is this a common issue? Is there a fix other than just replacing the whole down pipe from the turbo to the muffler?
Nero Morg
OR
2014 A6 TDI, 2001 Jetta TDI, 2014 Passat TDI
Maybe excess movement from the engine due to tired motor mounts... I'm still using the factory one on my car, and it's 326k miles old.
crashmanS
West Virginia
2003 New Beetle
Not that I'm aware of. I just replaced mine at 250,000 it was sucking fumes in the car in defrost mode. Not good.
Sent from my SM-N960U1 using Tapatalk
mrfiat
Los Ranchos, NM
2003 Jetta TDI (Reflex Silver) , 2003 Jetta TDI Wagon (Black)
You can use defrost while on recirculate. Just don't turn it all the way up and the defrost will still work.
crashmanS
West Virginia
2003 New Beetle
That is what I was doing till I got it fixed. But if I forgot when I warmed it up, it got all smoked up inside.
